Keeping mice out of your tractors engine bay over the winter and summer too.
   / Keeping mice out of your tractors engine bay over the winter and summer too. #131
Barn cats do wonders... but some will be list to predictors.
On the dairy farm a barn cat can be in constant motion...
   / Keeping mice out of your tractors engine bay over the winter and summer too. #132
i took a pail, filled it with water, made a ramp from scrap wood to the top.
Added a top rail with a cardboard tube with sundflower seeds taped to it.
4 mice so far,
none in car or tractor, so far.
   / Keeping mice out of your tractors engine bay over the winter and summer too. #133
4 mice so far,
I made something similar, worked for squirrels using Blackoil sunflower seeds floating on about 3gl Water in a 5gl bucket.
Can you post a picture of your top rail, I would like to try that, sunflower seeds don’t float for to long before sinking! Thank you
   / Keeping mice out of your tractors engine bay over the winter and summer too. #134
4 mice so far,
I use this trick too until the weather gets cold. My barn isn't heated so the water freezes. I'm looking at adding antifreeze or an electric heater.
   / Keeping mice out of your tractors engine bay over the winter and summer too. #135
Been using bucket traps for years, but stopped floating birdseed a long time ago. The seed doesn't float for long & the bucket get nasty after a few catches... (bird seed gets expensive) & I find it is not needed.
Been making these for years & they work great: (& cost me basically nothing)
(1) 4.5 - 5 gal bucket, I usually get them from a construction site for free. Two small holes drilled at the top across from each other big enough for the dowel listed below
(1) small wooden dowel; I've actually been using fiberglass driveway markers I get for free from a plowing / landscaping company when they have damaged ones. Just cut it long enough to be 2 -3" wider than the bucket you using.
(1) Plastic Water Bottle with cap - drill holes in the bottom & the cap just slightly larger than the dowel above.
(1) Scrap piece of wood for the ramp (usually a piece of scrap plywood)
(1) Rubber Band - to hold the ramp, so they don't knock it off
Basically after it is assembled I add very small amounts (dabs) of peanut butter to the center of the bottle & stick a few bird seeds to the peanut butter... (sometimes I will put a small smear of peanut butter on the inside of the bucket opposite ramp).
Add the water (I will use the RV non-toxic antifreeze in cold months) to the bucket & it done. They never get the peanut butter or the seed before dropping in.
The only thing to make sure during assembly is the water bottle spin super freely....
Oh & I hang a piece of scrap wire on the side of the bucket to pull the mice out of the bucket... save me from always dumping the bucket.
   / Keeping mice out of your tractors engine bay over the winter and summer too. #137
Why not just use snap traps? They are very effective, kill quickly, thus reducing the suffering, very cheap, and reusable.
I found it rare they work right and attract other critters if you don't empty them.
They also only take out 1 at a time, vs. the bucket where I have found 2 at a time.
I try to repel them and don't have any food as first line of defense though.
   / Keeping mice out of your tractors engine bay over the winter and summer too. #138
Lots of them on YouTube
   / Keeping mice out of your tractors engine bay over the winter and summer too. #139
I use snap traps also, they are cheap & reusable... but as @kenmbz stated they are a one & done if your not checking them daily (or more often). There are times I'm away from the garage & outbuildings for days do to work (or life) & the bucket traps just keep working.
   / Keeping mice out of your tractors engine bay over the winter and summer too. #140
View attachment 848783 View attachment 848784 View attachment 848785
Thanks for the pictures, love the idea of the dowel and not using much seed. The hanger is a game changer! ☮️✌🏻
2007 Deere 650J LGP (A53314)
2007 Deere 650J...
2015 Genie GTH-636 Telehandler (A54865)
2015 Genie GTH-636...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51246)
2021 HAMM HD+9I VO...
2012 MACK CXU613 DAYCAB (A55745)
2012 MACK CXU613...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
