brand new Kioti tractor with issues
/ brand new Kioti tractor with issues #21
I have only had this tractor for about 2 weeks. It is a Kioti RX 7320 with powershuttle and cab I noticed today that after running for about 1/2 hour the temperature gauge is still on cold although there was heat in the cab. I also notice that the hour gauge seems off. It is on 6 hours and I know i have not had it running for 6 hours. I bought this tractor for the construction trade so i am not running it for hours on end brush hogging or ....
I had read an article about someone who added a cab and had a similar issue. The tractor came with the cab already installed. I did contact the dealer but have not heard back yet.
Any thoughts?? Regards, Joe
I have a 2007 Kioti DK45hst. I purchase my tractor brand new back in 07 after 22hrs the wire harness caught fire and melted the wires. They replace it and three years ago the fuel injector pump went bad. Only with 800 hrs. Kioti had problems with their injectors back than and never had a recall. The Kioti dealer in my area wanted $3200. to fix and repair the injector system. My brother & I did it for $600. I have that repair on YouTube.
. I just want to say that my Kioti is a great work horse tractor. At this time I only have 1,400 hrs. All oil/filters changed all the time and grease fitting all the time. Garaged kept since new. Dealers don't get paid much for warranty repairs so it's very important to deal with the right dealership. Things happen so get yourself a factory service manual.
/ brand new Kioti tractor with issues #22
I do think how the tractor is stored and cared for goes a long way. Moisture and weather wreak havoc on all things mechanical AND electrical, and these units become more digital daily.
/ brand new Kioti tractor with issues #23
These are tractors, not sports cars. A tractor should be designed to be reliable and operate well in all weather conditions, from extreme heat to extreme cold and during heavy rains and snows. Many farm tractors stay outside much of their life. Sure, keeping it indoors keeps the paint and plastics nicer, but mechanically these things should perform.
/ brand new Kioti tractor with issues #25
Mechanically, sure... Even old reliable tractors suffer from electrical issues and gauge failures. Difference was, they didn't RELY on electrical sensors and wiring to RUN. These new more fragile units, do. Of course they should run well in all conditions... But storing them day and night in all conditions is a different thing. After being around tractors and equipment since the age of 6... I can say equipment stored well, is infinitely more reliable.
/ brand new Kioti tractor with issues #26
I don’t hear of many mice eating through wiring harnesses on tractors stored in a well constructed barn. Gauges aren’t fogged over/failing. Rust isn’t an issue. Corrosion in electrical connections, safety switches, grounds. Weather checked tires. Water in fuel. I would have loved for my dad to have had good storage for all of our farm equipment, we would have had a lot less down time.
/ brand new Kioti tractor with issues #27
The way I look at it, my truck has sat outside since the day it was new in 2005. It's a dually pickup and won't fit in my garage. I've kept it washed up, waxed, undercoated, and well maintained. It's not rusty at all. The front brakes are original despite the 150k miles on the clock. It's needed really very few things. I think a tractor is similar to a car. I don't argue keeping inside is preferable, but I think a vehicle or machine can still be well maintained and yet be stored outside and still expect a long service life.
/ brand new Kioti tractor with issues #28
Yes and no. No here in north idaho. Snow and cold, etc takes its toll on all equipment left outdoors. In so calif, I would not hesitate to leave something outside.
/ brand new Kioti tractor with issues #29
Arguably, you cannot compare the weather tightness of a cabbed truck to an open station tractor. Nothing on the truck is really exposed. Most tractors have fairly open engine compartments, and operator stations. Wires, hoses, sensors are all quite exposed to elements. My cars have lived outdoors most of their lives too, until recently… but I wouldn’t compare that to leaving my 72” ZTR in the elements for 10 years.
/ brand new Kioti tractor with issues #30
When I Sold my jd870 in 2010, the tractor was 14 yo with about 1500 hours. It still looked new. Got more than I paid for that tractor. It was under cover for entire time I owned it. That’s why it still looked so good.
everything I own is stored under cover. If I have no place to store it…..I dont buy it.
/ brand new Kioti tractor with issues #31
I live in central New Hampshire. We get a lot of snow, cold, and road salt. The truck sits outside.
My tractor is a cab tractor; everything inside the cab seems as protected as something inside the truck. Some things are more exposed, but if you look in the front wheel arches of a pickup, you can see the engine, and obviously everything is open below.
/ brand new Kioti tractor with issues #32
You convinced me, parking equipment outdoors is the same as dry indoor storage.
/ brand new Kioti tractor with issues #33
When looking at used units a year ago… it was sad to see the degradation of units that were only a couple years old, that clearly sat out. They looked like they had a decade of use. Which was in large part why we spent a little extra, to buy new. I’d have saved money if I had been able to find a low hour shedded unit. A lot of people don’t have that storage option.
/ brand new Kioti tractor with issues #34
If you read my previous posts, I state on at least two occasions that if you can keep your equipment inside, that's going to be better - at least cosmetically. Unfortunately with tractors, the paint quality is usually not that great and the plastics fade quickly. I think JD green holds up maybe the best, including their pigmented plastics. My Kubota sits in cold storage. It's also worth noting the dealers keep all their inventory outside year round. A brand new machine may have sat in the hot sun and cold winter for a year when the owner buys it. Waxing the paint can help preserve the finish if the machine will sit outside.
/ brand new Kioti tractor with issues #35
Well, I guess I just value my equipment more than you do yours. Its all up to who ever owns it.
I think if we all had the luxury of a building that is heated that would be the best option. Mine is new and its been as low as -22 recently.
I have put a tarp over the engine/loader I am a cabinetmaker by trade and being meticulous runs in the blood.
I also agree that keeping a machine in as perfect as possible condition is also a wise investment in the event of resale.
I do leave my shovels and rakes outside as its a minimal investment. I also bought a new 22' 14k tilt trailer to haul my tractor and I have a tarp on it as well. This way I will be able to add some sealer type of finish on it when the weather warms up.
Ah, what a wonderful world :)
/ brand new Kioti tractor with issues #37
There’s always an option to store equipment under cover. It just depends on whether or not the owner is willing to take the effort to construct something. Before I bought a place with a barn, I constructed carports and pole sheds for equipment.
/ brand new Kioti tractor with issues #38
Ok, then many just don't care. $30k is a lot of money to me, so having it well kept, was very important
I have purchase treated 4X4s' long
I will place them in the ground with 11' sticking up 10' apart for the tractor width.
I will create 3 simple trusses and connect them to the poles and then add some 2X4s at about 3 or 4' intervals.
I have a heavy tarp that is30X40 to drape over the truss assembly.
Thus a 10'X30' tractorport sort of :) This will enclose it on 3 sides.
I will strap down with bungee cords.
My tractor is about 60k so its worth it to give it at least something thru till I can do something better. :)
/ brand new Kioti tractor with issues #40
Hope you don’t get snow. A 4x4 isn’t very sturdy against shear forces.
TRI PAC EVOLUTION APU (A60736)
TRI PAC EVOLUTION...
2006 TerraGator 8104 (A61307)
2006 TerraGator...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
2016 HAMM H7i SMOOTH DRUM ROLLER (A60429)
2016 HAMM H7i...
