Can I add anti-gel to my tractor
   / Can I add anti-gel to my tractor #1
bigtiller
Super Member
central Iowa
John Deere 2720 John Deere 3039R John Deere Z545R
I have never added anti-gel to my tractor because it sits in a heated garage and it takes less than an hour to clear my driveway.
But it is -15° F and the neighbor wants me to blow a 4' x40' drift in his driveway and I am concerned about the fuel gelling. Both driveways may take 2 hours.
If I pour some Power Service White Bottle in the fuel tank before I head outside, is there any chance it will get mixed up and do it's job before gelling?
   / Can I add anti-gel to my tractor #2
I use PS White Bottle year round. If you have "winter fuel" in it now, I'd add it and give it a try. PS also has "911" for emergency use, but not sure if anywhere near you sells it, on Sunday. I cleared my drive yesterday morning when it was pretty windy, but not this cold. Maybe wait a bit? It's supposed to warm up later today, to -4.
   / Can I add anti-gel to my tractor #3
Yes, there is a good chance it will mix in pretty well. Not all the fuel pumped goes to run the tractor, some of it returns to the tank. This causes both warming and mixing of the fuel in the tank. Let it idle a few minutes. In addition to being mixed because of return, driving the tractor will cause the fuel to slosh a bit in the tank.
But when did you buy your diesel? If you bought it after the beginning of Nov. then there is a good chance you have a winter mix to begin with and shouldn't have a problem.
   / Can I add anti-gel to my tractor #4
I quit using the PS products as they have failed in more than one situation.
Today, I just pour in 1 bottle into the tank of,
   / Can I add anti-gel to my tractor #5
My tractor is in a semi heated garage (about 40-45 deg.F). I too use PS year round. Adding some to your tank before taking it out for a couple hours I think the vibration of the tractor will mix it just fine. At -15 F I would use it.
   / Can I add anti-gel to my tractor #6
I would also add an anti gel regardless of how long you intend on being outside. Not likely to be a problem for a short time, but the fuel in your primary sediment bowl filter is particularly vulnerable.
That's another thing that concerns me, I bought it in September.
Would it help or hurt to add a double dose or would I be better off following the directions on the bottle?
   / Can I add anti-gel to my tractor #8
Depending on the fuel bowl, if you have the small stubby one, it's best to see if a taller one with filter would fit on the machine. I find this to be a great help. More filter surface area allows the machine to run longer, possible enough to get out of the field and to a garage to do a repair or new filter and bowl cleaning. Plus the taller gives you a better eye to see if the bowl is getting clogged and the sediment at the bottom of the bowl.
Waiting until this afternoon is a good idea, -4° is better than -15°
   / Can I add anti-gel to my tractor #10
Double dose would foul the engine as it's not really fuel.
   / Can I add anti-gel to my tractor #11
Double dose would fould the engine as it's not really fuel.
I've been "liberal" in adding it before, but twice the recommended about? No.
   / Can I add anti-gel to my tractor #12
Double dose wont hurt a thing.
Have helped start a lot of equipment for others that never got the fuel treated properly.
Dumped a bottle of PS in the tank and filled the filter housing with PS they will start and run fine.
Have never used the 911 bottle but always kept a supply of the white Power Service on hand. Still do.
   / Can I add anti-gel to my tractor #13
PS recommends double below 0f. I wouldn't hesitate to do that.
Good to know, I'll follow directions.
It has an 11.8 gallon fuel tank so I'll check the gauge and do a best guess as to the gallons remaining and add accordingly.
Would 5 minutes idling at 1600 rpm be enough to get a good start on the mixing?
   / Can I add anti-gel to my tractor #15
To clarify. I have 32oz bottle that says add the entire thing to 100 gallons, add to 50 gallons below 0. The latter is what I mean by double dose and it will not hurt anything. I've been adding this amount to every bit of diesel I've purchased.
Thanks for the info. I will do a thorough reading of the bottle.
   / Can I add anti-gel to my tractor #17
Used PS for 20+years,treat all fuel ,year round.Never a problem.Cheap insurance.
   / Can I add anti-gel to my tractor #18
If your tank is not full, fill it up after adding the anti-gel and that will help mix it.
   / Can I add anti-gel to my tractor #19
You do have an full extra can of fuel on hand, I hope. Good idea to read the instructions. :) My bottle(s) are out in the shop, so I can't quote the specs from memory.
   / Can I add anti-gel to my tractor #20
Both Yanmar and Deere state not to idle more than 10mins max. Too long of an idle creates soot on the exhaust side.
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
1992 Norris Long Basket Trailer (A55973)
1992 Norris Long...
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2018 CHEVROLET...
2022 KOMATSU D71PXI-24 CRAWLER DOZER (A60429)
2022 KOMATSU...
2021 JOHN DEERE 50G EXCAVATOR (A60429)
2021 JOHN DEERE...
20 UTILITY TRAILER (A55745)
20 UTILITY TRAILER...
