school of shifting :-)
/ school of shifting :-) #1
ironman1952
2023 Kioti RX7320pccb
This almost embarassing. My second car was a 54 chevy with 3 on the Tree :) Okay maybe i should have gotten the hydrostatic trans.
SO i need some serious schooling :) My trans is the shuttle shift with the creeper gears so choice ugh:-(
So cruising along no issues but digging with the loader, what is the best most effective gears to use?
I was diggin up some soil on the property which is about 85% sand and I was in low/2nd gear and the back wheels just started to dig in making a rut.
I turned on the 4X4 and just seemed to make the tractor hop.
at 74 hp this thing should dig up sandy soil like digging up butter. I am sure its operator error. BTW my rear tires are filled.
When is the best situation for 4X4?
I am also going to rent an auger for the front end loader, any advice?
Regards,Joe
/ school of shifting :-) #2
If digging I would use the lowest gear 4 wd and try to be constantly aware of how much digging it is doing. Don't make a big hole unless that is the object. Keep a long gentle slop into the pile. Raise the bucket as you go in and curl to fill.
If the machine stops forward progress raise the bucket a bit and reduce the bite. There can be a lot to do. Its a dance... lower gear & 4wd to to fill the bucket then 2 wheel drive and higher gear to transport if that is what you are doing.
/ school of shifting :-) #3
Regards,Joe
Use a low enough gear that you are not going too quickly when you are at a reasonable engine operating speed. Exactly what gear you use depends on the transmission.
A loader bucket is not that great at digging, particularly if it does not have teeth on the bucket. Think of more trying to take slices off of the top of the dirt until you've dug what you want to dig. Spinning tires in 2WD and hopping with MFWD engaged means you are trying to push into something that doesn't want to move.
MFWD is only to be used when you are on loose surfaces, do not use it when you are on pavement. The front wheels spin faster than the rears. If the front wheels can't slip, you bind up the driveline and break things. Personally, if I am using a tractor with MFWD, I treat it like a conventional transfer case part-time 4WD on a truck, I only engage it when I need to.
Regarding an auger, make sure that you don't get one that requires too much hydraulic flow or you would need to have some auxiliary PTO-powered hydraulic pump setup. Most augers are designed for skid loaders, which have a lot more hydraulic flow than a utility tractor. Appropriate ones are out there but you would need to be careful when looking.
Thanks for helping me figure it out. I would have bought a skid steer but they are up around 80k for a new one.
/ school of shifting :-) #5
For digging use a gear you are comfortable with without being overwhelm by it at full rpm (safe operating limit while at max hp or close to it) and take slices off of what ever you are digging, don't take too big of a bite scoots explained it very well, remember the tilt is stronger then the lift so tilt is your friend.
One thing to note with a full bucket watch your steering impute don't crank the steering keep it at 50% to 75% of its steering capability if you go more then that it puts unnecessary stress on your front axel.
Used 4x4 only when you need it, with a full bucket and while digging you most likely do but if you don't you don't, rear wheel spinning = 4x4 needed, but I don't spend my time engage it and disengage it ether if I notice I need it I engage it and it stay there until the task is done or until I get to a situation where is a big no no to be on 4x4, for me the big no no on 4x4 is at high speed and on surface that doesn't offer any slippage like concrete or asphalt.
  • Good Post
Reactions: bgr
in the words of the old irish actor on far and away "Very Wise"
Thanks, very well put :)
/ school of shifting :-) #7
Stop digging with your loader and get a box blade. Both you and your tractor will be happier. Scoop up loose material with the bucket.
/ school of shifting :-) #8
Tractors don't dig very well. Tractor loaders are more for scooping up loose material from a pile than digging. The suggestion to use a box blade to dig is a good one. Tractors are a lot better at pulling implements than pushing them.
When you're using the loader to scoop up material, drive slowly into the pile while lifting and curling the bucket at the same time. Just driving straight in won't work nearly as well. Even a loose pile will stop the tractor before you have filled the bucket.
/ school of shifting :-) #9
on my 12 sp, i always use low range 1st or 2nd in 4wd. that way i have time to catch any bind. to me, using taller gears puts stress on the entire drive train. keeping in mind, as mentioned, tractors are not meant for excavating, regards
Great advice from all Thank you :)
I am going to be building a house soon and I think I will just rent a mini excavator to do the digging and the tractor to move the dirt.
Thanks :cool:
/ school of shifting :-) #11
Lowest possible gear and keep your foot off the clutch pedal and certainly don't slip it. I have hydraulic shuttles on both mine and I never touch the clutch pedal, always the shuttle lever.
/ school of shifting :-) #12
My best advise is don't dig with a loader bucket. Spinning and digging those wheels in is putting huge stresses on the loader arms. If you're gonna dig, start a Gofundme to repair your loader.
/ school of shifting :-) #13
OK, help out one of your slower readers here. What is "MFWD"? I get the "FWD" but what is the "M"?
/ school of shifting :-) #15
Kind of like all wheel drive vs 4wd in tractors.
Mechanical
Front
Wheel
Drive
Thanks!
So, it's not "four wheel drive"?
What is the alternative to "mechanical" in this context?
Unlike cars, there are no "front wheel drive only" tractors, or tractors with AWD, are they?
You've got me curious now. I thought it was just rear, or rear+front, and maybe a differential lock or two.
/ school of shifting :-) #16
Thanks!
I’m not 100% sure, I know it has something to do with how the tractor has four wheels Turing that are two different sizes (front vs back). One is a lot more like front wheel assist and the other one will literally grind your tires down if your on pavement which I think is the MFWD.
I am also a newbie but I will take a stab at it. The front wheels drive when the switch is thrown that engages them. I also think the amount of drive is probably equal to the weight that is place on them. Since my wheels are weighted I think there will be more driving affect with them unless the load on the front is equal they wont offer as much drive as the rear.
Thats my uneducated guess :cool:
/ school of shifting :-) #18
Thanks!
You've got me curious now. I thought it was just rear, or rear+front, and maybe a differential lock or . And that is why it is called 4wd.
What 4wd means for compact tractors - and also most 4wd PU trucks - is that there is an operator control that tells the transmission to send power to drive the front axle as well as the rear axle. When the front axle is also powered it is then possible for any of the 4 wheels to be driven...hence: 4wd
But a because each axle has a differential, driving all 4 tires at the same time also requires some way to lock the differentials. So without "lockers" you only get 2 of the 4 driven at any time....but that's another level of complexity.
You also asked what is the alternative to "mechanical". It is "hydraulic" - drive via a fluid motor in the axle or hub instead of by driveshaft and gears. MFWD vs HFWD.
HDFD and AWD is not nearly so common as 4wd via MFWD in the under-100 hp tractors.
However, MFWD is simple and relatively cheap to manufacture since the invention of the front bevel drive - about 1975. The big downside to 4wd MFWD is that it is a part time traction improvement for getting through difficult places & not for using full time. 4wd is not AWD; it lacks the necessary center differential that all AWD have.
There are a few compact tractor sized AWD full time true 4wd tractors with Hydraulic Front Wheel Drive instead of MFWD. The Bobcat Toolcat is one, the USA made Ventrac is another. Both excellent, not too common, and relatively expensive. Also you will find that type of hydraulic drive on larger European tractors and big construction machines like skip loaders.
Hope this helps,
rScotty
Well put and easy to understand :cool:
/ school of shifting :-) #20
All the new pickups that I have ordered I ordered positraction and I
could go where some of the 4x4 pickups were getting stuck with no
problem but I put weight in the truck bed. With the possi both back
wheels would turn and the 4x4's did not have the possi
willy
UNUSED SDLANCH HYD DUMPER (A64280)
UNUSED SDLANCH HYD...
2018 Bomag BC572 Articulated Refuse Compactor (A61572)
2018 Bomag BC572...
2015 FORD F-350 XL SUPER DUTY 12' BOX TRUCK (A64280)
2015 FORD F-350 XL...
2012 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2012 Chevrolet...
Caterpillar 330BL Excavator Service and Parts Manuals (A63117)
Caterpillar 330BL...
Industrias America 435 (A64119)
Industrias America...
