2manyrocks
Super Member
- Joined
- Jul 28, 2007
- Messages
- 9,599
If it were me, I'd rather buy a new engine if it came to it than have a heart attack shoveling snow.
I drive the tractor more because it's fun and saves time, but I can still do physically strenuous stuff and I'm thankful for that. I'll be 63 in a few weeks. Maybe things will change with time.If it were me, I'd rather buy a new engine if it came to it than have a heart attack shoveling snow.
I think the key is to stay active. Then small bursts of exertion won't hurt you.Sitting on the couch not doing anything can cause a premature trip to the cemetary. I'm at the point where I have to decide what's good exercise and where to draw the line.
Did you have someone to start the pt and watch to see where the oil is coming from before you pulled the engine? Is the leak like a weeping leak or is it spraying. If it is coming out of the tunnel, from the engine or from the pumps, or the oil tank? My 425 pt is a 2003 model and I have had to replace the hose for the quick attach, but I have noticed a few drops of oil on the floor between jobs. I think my hoses are weeping some but not bad enough to replace yet. If I ever see oil coming out of the tube going through the center section with the blue tube I plan on replacing them all at the same time . I will buy new hoses and fittings to connect the new hoses to the old hoses and pull in the new one as I pull out the old one. Last year I had to replace the fuel pump and the oil sensor. The fuel pump started leaking gas through the oil sensor and the gas went into the oil system and filled the oil pan up and it over flowed and pushed out what I first thought was oil but I could smell the gas and the dip stick was full to the top and you could smell the gas. Didn't cost much to fix , changed the engine oil changed oil filter and changed the fuel filter, it runs good now.Maybe best to find out first where the oil leak is and see what it would take to repair it.....
Just saying
Winner winner chicken dinner!I have a very similar design Vanguard 35 hp engine in a Vermeer stump cutter and am very interested to hear where the engine oil leak was once you have located it?
The oil filter/oil cooler setup would be the first place I would take a look at, followed by oil pan & crank seals.
Diesels are much more efficient and longer lasting as well and as far as fuel gelling in cold weather, a shot of Power Service silver label cures that issue no sweat. One thing to keep in mind is a diesel will be purring along, long after that gas motor is completely shot.I dislike diesel.
Can't stand the smell of it if it gets on my clothes. And, I've never failed to get a gas engine to start in cold weather. The little CH25 Kohler has started as low as -15F with just a shot of starting fluid.
Diesels, on the other hand... I used to work with a lot of them when I worked at the airport back in the 70s and 80s. Gelled fuel was the biggest problem. All required pre-heating. All cost a lot more, etc.
Now it does not get as cold here as it used to, but I need it to start if it does. I don't want to have to treat fuel, pre-heat, etc.
When you think about a machine like the PT425, all it is is an engine spinning pumps. 25HP is 25HP, no matter what makes it. The pumps do not know. I'll lose traction and spin the tires way before the engine bogs down.
In my opinion... hahahahaha, I see no need for a diesel for my own uses.
For that matter, my first tractor was an IH2500b tractor loader. 8000# machine. 50PTO hp. Cab. Dedicated loader on the front and 3pt hitch on the rear. It was hydrostatic and had a gas engine.
Did I mention I dislike diesel?![]()
And much more expensive, and too large to fit in the unit...Diesels are much more efficient and longer lasting as well and as far as fuel gelling in cold weather, a shot of Power Service silver label cures that issue no sweat. One thing to keep in mind is a diesel will be purring along, long after that gas motor is completely shot.
I repaired an oil leak on a friends Xmark o-turn with a Kohler 26hp. it was the crank seal. another person replaced it twice, still leaked. I inspected it and kept cleaning and looking at the seal when it was seeping. it was leaking around the outside of the seal, I got a new one and put a light dab of silicone around it and installed, problem solved,fortunatly they also had a big forklift so we raised it up in the air & I removed the pto clutch then the seal. then put it back togetherMy 2001 PT425 developed an oil leak. About 1/2 a quart every 20 minutes. Can't seem to locate it, other than a pool of oil under the engine. So time to pull the engine, put it on a stand, clean it up, and run it to locate the leak.
Trying to avoid disconnecting hydraulic hoses.
Pulled the gas tank and fuel pump all on the bracket. Just 4 bolts and a hose clamp.
Pulled the muffler. 4 nuts. Didn't break the exhaust studs this time.
Pulled the battery.
Unmounted the hydroback assembly.
Disconnected the wiring harness and positive battery cable from the starter.
Disconnected the tram pump from the mount on the front.
Disconnected the PTO pumps from the engine on the rear.
Removed the 4 bolts that hold the engine mount to the bottom of the tub.
Started lifting the engine and found one (1) hydraulic hose that goes through the engine mount. Grr.
Pulled the right rear tire, cleaned the fitting, bagged it and pulled the hose.
Pulled the engine.
View attachment 831634 View attachment 831635
Took about an hour and a half. Overall, not too bad.
I'm going to get a cap/plug kit and pull the hoses off the pumps, reassemble everything after locating and repairing the oil leak, and put it all back in as one unit. That will be much easier.
I think that Superclean degreaser is amazing at getting oil off. Of course it has lye in it, so eye and skin protection is a must.Getting new paint to stick might be a challenge.
I'll power wash it, then wipe it down with something to get any oil off. Doesn't have to be pretty.Getting new paint to stick might be a challenge.
