Tach drive location on a 2005 Shibaura.
/ Tach drive location on a 2005 Shibaura. #1
Norseman67
2005 New Holland TZ25DA
This seems very simple. However I I cannot locate the tach drive location on my 2005 Newholland TZ25DA Boomer tractor. I just changed the oil and noticed the cable hanging. Its not easy to see the drive location with the loader on. Any help is appreciated.
/ Tach drive location on a 2005 Shibaura. #2
Welcome, I can't help you here as I no longer own my Case IH branded version of that same tractor. But they are nice units.
/ Tach drive location on a 2005 Shibaura. #3
It must be in the upper right front corner of the timing gear cover. I don't see the drive unit itself listed in the parts book, but item 9 in this diagram is described as gear, tachometer shaft. The drive can't be far away.
Harry in KY
Thanks!
For anyone else with this issue, the top cable is the tach/ hour meter drive the bottom cable is the throttle. Both seen in the top photo.
The close up second photo is where the tach cable screws in the back of the injector pump. There was no way to see this location with the side engine guard on. I also had to take the loader off to reattach the cable.
I hope this helps someone. I could not find this information anywhere online. My cable popped off during an oil change.
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
30KW GENERATOR (A58214)
30KW GENERATOR...
ASSET DESCRIPTIONS & CONDITION (A59905)
ASSET DESCRIPTIONS...
