Stupid Things I Have Done
   / Stupid Things I Have Done #451
Buddy of mine putting a dryer vent in his house with a hole saw ripped off a gigantic run of vinyl siding f- up his wrist, couldn't understand why, thought the hole saw was defective or something, I told him to fix it, I came over ran the hole saw in reverse to get thru siding. Of course some bystanders will make a snarky comment about the drill being in reverse initially lol
   / Stupid Things I Have Done #452
Whether cutting a threshold with carbide or vinyl with a hole saw, it's the same problem: Tooth pitch any greater than material thickness can cause it to catch, with the resulting action being either breakage or throwing of material or operator. Running in reverse is always a way to avoid this, and in fact I remember guys installing circular saw blades backwards to cut siding 30 years ago, because they didn't have the right blade for the job on-site.
I do a lot of work with bandsaws, and often have to change band blades to accommodate different material thicknesses. That's a lot more work than changing a circular saw blade on any machine, by the time you reset the guides and all.
   / Stupid Things I Have Done #453
That's the easiest way to drill holes through drywall with a hole saw as well
   / Stupid Things I Have Done #455
So many times...
How about it's 10°F outside and sleeting...so two pair socks, briefs, union suit, t shirt, sweatshirt, thermal pants, suspenders, lace up boots, down jacket, heavy gloves, ski mask...then outside.
Stomach pain? Maybe it's just gas? Uh-oh...that bean burrito wants out! ...so back inside...can I make it in time?
   / Stupid Things I Have Done #456
   / Stupid Things I Have Done #457
Thanks for sharing, the whole family just cracked up!😂😂😂😂😂☮️✌🏻
   / Stupid Things I Have Done #458
That's like ice fishing, when you have to pee, and you're wearing 3" of clothes, and have a cold 1" wee wee to get out 😳
2011 Big Tex 18' Trailer, VIN: 16VCX182XB2E04765, Tandem Axle, GVWR: 7,000 Lbs., Asset# 25 (A59076)
2011 Big Tex 18'...
2020 DRAGON ESP...
2019 BOBCAT T590 SKID STEER (A52709)
2019 BOBCAT T590...
2007 Terex (A55973)
2007 Terex (A55973)
2016 Freightliner Derrick Digger Truck (A55973)
2016 Freightliner...
IRON FORCE IMPACT SET (A58374)
IRON FORCE IMPACT...
