Oil & Fuel Dealship bad
/ Dealship bad #1
Green Acres Homestead
NewBrunswick & Nova Scotia www.lostcaper.com
Kubota L4740 sold. As of Jan 2023 I have a new L2502.
Bought a new kubota L2502 tractor. Did two hours worth of work. I checked the transmission dipstick. The level was below the low level line. Pretty sure it is leaking. I previously had a lot of service trouble with the dealership. Peaved off.
Tomorrow when it opens they are going to here it maybe even tell them to come pick the tractor up and cancel my contract.
/ Dealship bad #2
How old is it? How many hours only two?
/ Dealship bad #5
green acres
If you had previous problems with this dealership why did you purchase another item from them?
Like others have said not unusual to have to top off transmission on new tractor especially ones with small reservoir.
I have changed oil in mine 3 times since new and have had to add around quart to half gallon every time after operating for hour or so.
/ Dealship bad #9
Should be called “Bad Owner” lol. What does “ pretty sure it’s leaking” mean? It’s leaking or it’s not. A big oil puddle would mean it’s leaking. If nothing underneath….it needs topping up. It’s new and all fluid/oil levels could settle and NEED to be checked regularly from now until it’s replaced with a new tractor. Then start the cycle over again or hire someone to do the work for you…
Let us know what happens when you contact the dealer if you dare 😬
/ Dealship bad #11
I honestly doubt we’ll ever hear from this guy again…..
Not so sure, since he has over 1000 posts and been a member over 10 years.
That said, top the new machine oil levels off.
Park it on a clean area and verify whether oil leakage is actually happening.
/ Dealship bad #12
Glad you took the time to bounce the idea off your faithful brethren here.
Like others have said, are you nutty? Fill the damn thing up and make sure it’s not leaking.
/ Dealship bad #15
GAH take deep breath and step backwards...doubt very much dealer will refund so think of your next step to correct problem.
/ Dealship bad
I took the step back. Dealership came through with the fixes. Tractor is working perfect.
/ Dealship bad #17
So are you saying there were leaks?
Andddd it took them a year to fix the leaks???
2005 Komatsu PC 200 LC (A60462)
2005 Komatsu PC...
2010 Massey Ferguson 2625 (A60462)
2010 Massey...
2006 GODWIN GHP45KW-RC 45 KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
1994 SHOP MADE ENCLOSED TOOL TRAILER (A58216)
1994 SHOP MADE...
2012 Caterpillar CB54 Articulated Tandem Smooth Drum Roller (A61572)
2012 Caterpillar...
1998 Ferguson 46B Compactor / Roller (A62613)
1998 Ferguson 46B...
