Fuddyduddy1952
Super Member
- Joined
- Aug 10, 2022
- Messages
- 7,952
- Tractor
- john deere
It would be helpful posting pictures of it. Module & connector end. Then open it, pictures of the pcb (circuit board) component and foil side.
TractorTech Ted, I have searched the world and I have a question. I know very little about tractors. After25 years I wore my Kubota L295 only 29 hp out. I built roads and ponds with my JD 555 track loader backhoe. I wish I still had it I built many things cars, sailboats etc., but this N H Ford 445c mystifies me with the TCM. Ted do you know if it's possible to attach an on-off- on toggle to the reverse and forward solenoid with some kind of voltage regulator for the solenoids? BTW I'll be 90 in January.Yes it is. The difference between the 8x8 and 4x4 is the PTO and the torque converter lockup function. The lockup is the button on the shifter, but New Holland discontinued the 8x8 controller first, leaving the 4x4 controller F0NN7Z319BA R/B 83991713 which also is not available anymore. Look at the thread as this is a viable alternative. Otherwise, you will have to find a salvage unit or have it rebuilt
Ted, you can't imagine how good I feel about you and others stepping in to give me a hand on this Holland 445C. I was floundering. A neighbor checked all the systems except the voltage regulator, which I'd better figure out. The module checked negative. I tested it a couple times per the manual.Beautiful sailboat!
I was searching last week when you asked, but work and Christmas took over. I will make some calls tomorrow.
Question, you know for sure that the controller is the culprit?
Other option would be the solution eKretz came up with. Stat tuned.
Using a toggle would shift the tractor very abruptly. It could be used very short term, but not recommended.
Ted
TractorTech, The only possible solution I've found is what Ekretz is doing. It's an inexpensive investment, so no loss there if it doesn't work for me. When it comes, I'll probably just stare at it for a while. I would like to keep in touch. Here's another of my projects. I've spent a lifetime dreaming and wasting money Have a wonderful Holiday.Yes it is. The difference between the 8x8 and 4x4 is the PTO and the torque converter lockup function. The lockup is the button on the shifter, but New Holland discontinued the 8x8 controller first, leaving the 4x4 controller F0NN7Z319BA R/B 83991713 which also is not available anymore. Look at the thread as this is a viable alternative. Otherwise, you will have to find a salvage unit or have it rebuilt
