Kubota RTV 1140 transfer pump issues.
/ Kubota RTV 1140 transfer pump issues. #1
plasmaguy
Member
Pinnacle, North-Carolina
IH 1026
Hello everyone. My Kubota is having fueling problems. My first diagnosis was that cam driven transfer pump had failed. Machine has 2,900 hours. I replaced it and problem solved. Several months passed and the issues came back. I tried an electric 12V transfer pump and problem solved.
Now as you're guessing the problem has re-surfaced a third time now. A retired diesel mechanic, Detroit, Cummin, CAT , guy is say I need to measure to pressure on the discharge side of the injection pump. Don't have the gauges required and may take to the dealer.
I wanted to ask on this forum beforehand.
Thank you all.
Tom
/ Kubota RTV 1140 transfer pump issues. #2
The inj pump only needs 6-8 psi to operate correctly..
The supply pumps seem rather cheap to buy..
Do u run the tank dry often.?
THAT would ruin a pump before it’s time..
/ Kubota RTV 1140 transfer pump issues. #4
I’m trying to figure out WHY the electric pumps are failing.. R they cheap 10.00 pumps from China.??
R the pistons seizing up from lack of lubrication.?? Or the diaphragm tearing for the same reason.??
Update time. I installed a new electric transfer pump and in have no fuel exiting the injectors.
The fuel solenoid is new also.
The only thing I think that can have failed is the injection pump.
/ Kubota RTV 1140 transfer pump issues. #8
Is there an air bleeding procedure on this model?
No fuel out 1 injector or all injectors?
Are you certain the solenoid is activating?
Did you disconnect the feed line at the injection pump to make sure you are getting fuel to the injection pump from the transfer pump?
/ Kubota RTV 1140 transfer pump issues. #9
Yup.. as MTGREEN ASKED, MAKE SURE u have fuel UP TO the inj pump.. put the throttle in the wide open throttle position and crank the engine..
U can leave the steel lines off of the pump.
Let us know what happens..
Good luck
Good luck
Thanks guys.
I have fuel coming to the pump. I will check tomorrow and report back.
MTGreen, yes sir, the new solenoid is working. We have fuel at the pump. I have all three nuts at that connect injectors broken lose also.
/ Kubota RTV 1140 transfer pump issues. #12
On that mdl tractor, does it have a cover plate right below the inj pump.??
Usually has 4-10mm bolts holding it on..
U can remove the plate and see if the pump control rack is moving or if it’s stuck..
OR.. if u have the shut off solenoid that screws into the inj pump hsg., u can unscrew the solenoid and reach in with a pick or pencil to feel if it’s moving..
Pump guy
Thank you for your help. I haven't had a chance to open it up yet.
Attached is a picture of the pump.
thepumpguysc,​
I am getting back on this project.
We have installed a rebuilt the fuel injection pump. We are still not getting fuel to the injectors all the time.
1. We have the solenoid removed and the rack is in the open position. I think the rack is always open unless the solenoid in mounted and then turns fuel off.
2. We have fuel coming to the pump with an electric fuel pump.
We are getting fuel to the 1st and 2nd injectors but none to the 3rd. The lines are removed.
With the fuel pedal pressed to the floor there's little change.
I am sure open to any suggestions.
Thanks,
Tom
/ Kubota RTV 1140 transfer pump issues. #15
So u changed the pump.??
And still have the problem.??
Common sense tells me, it’s not the pump..
Take the pump back out and check the lobes on the camshaft that drives the pump..
We are using an electric lift pump, the cam operated pump is out of the equation. There's plenty of fuel going to the pump. The solenoid is out and the rack is in the run position.
/ Kubota RTV 1140 transfer pump issues. #17
Sorry, my mistake.. I was talking about the inj pump..
Pull it back out and check the cam lobe in the engine that operates it.
& while the inj pump is out, make sure the roller on the bottom of the inj. pump has spring tension on it..
It’s possible that if the pump has sat on the shelf, the plunger in the cyl that’s not pumping, is stuck in the up position..
You can tell by the roller not having spring force in the down position.
Also make sure the inj pump control rack will move left and right very easily..
Hello Pumpguysc,
We're starting back on it next week. The spring tension is an interesting point. I will let you know what we find out.
Thank you sir.
Happy Easter.
Tom
2006 Freightliner Auger Truck (A61306)
2006 Freightliner...
2025 14ft. Bi-Parting Driveway Gate (A59231)
2025 14ft...
2013 KENWORTH T680 TRI AXLE SLEEPER TRUCK (A59905)
2013 KENWORTH T680...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
2017 Ford F-550 Crew Cab Enclosed Service Truck w/ Liftgate (A59230)
2017 Ford F-550...
