Sportsman762
- Joined
- Mar 28, 2008
- Messages
- 1,002
I used forks for moving 5x6 twine bales and they worked good enough. Hay Dude lays out the points well. Used a rough terrain forklift a few times when the skidsteer or backhoe was at another farm. Bale Spear is much easier and does not require any skill. A Squeeze Grapple like @LouNY recomends is nice in that it does not hurt bales at all, however they are much slower. With a spear I could grab a bale without stopping making hay moving much faster. Also Squeeze Grapple are much more $$ than a spear. Normally I see them when folks are doing haylage bales that are individually wrapped. The Squeeze Grapple is the only way to move the individually wrapped haylage bales without damage.Are they net wrapped? Or string? What size? 5’ wide?
If net, you can, but spread the forks pretty wide and be VERY careful. If they are narrow set, you’ll either tear through the net, or dig up dirt under them.
