NEED help !!!! Snow Thrower / Blower
/ NEED help !!!! Snow Thrower / Blower #1
kormidoit
Lake Almanor, CA.
2021 LS MT225S, 2003 Kubota BX2200
I have a LS MT225S...I need 4 of 5 ft snow thrower /blower RECOMENDATIONS from you tractor people please.....So many choices.
Will the 225 handle a 5 ft. ?
What is the min. lifting power ?
! know I have 19.3 PTO HP....but how does that fair when the blower is rated 18 to 30+ HP on the 5 footers??
What brand would / do u have or recommend ??
I am looking at WOODMAXX SB 48 AND 60 .....the TITAN 47 and 58.
I need to purchase this week....expect delivery before snow in 10 / 14 days. ANY help is appreciated.
/ NEED help !!!! Snow Thrower / Blower #2
I’m no help but sure hope you can get one this time of year in less than two weeks.
/ NEED help !!!! Snow Thrower / Blower #3
If your tractor is equipped with Hydrostatic transmission so you can easily control your speed either size blower should work. I would recommend a blower that’s slightly wider than the wheels on your tractor.
I have 2" spacers on my MT225S...brining it to 52 inches. I do have a hydrostatic trans....Other concern is pick up weight on my 3 point.
/ NEED help !!!! Snow Thrower / Blower #6
As cycledude states, cover the width of your tires at a minimum. The weight should not be a problem, and it's within the lifting ability of your 3 point. Worst case is that without a loader on the front you may need some front ballast weight.
Wet and heavy snow can bring even much larger tractors to their knees. Adjust the speed and cutting width based upon snow conditions.
/ NEED help !!!! Snow Thrower / Blower #7
How log is your driveway, what distance will you be blowing?
Is the surface gravel or paved, flat or hilly?
Do you get a lot of ice, if so you might want to consider a set of chains.
Ice covered with a dusting or so of snow is incredibly slippery add in hills and on our property you are not going anywhere without chains.
/ NEED help !!!! Snow Thrower / Blower #8
I have a LS MT342 with 6 Ft front mount blower, At my home driveway that is about an eighty foot horse shoe, the tractor works great, but I have property seven miles from the house and that is about a forty and a half long with a big open field on the north side that likes to drift in. When I am doing this drive-way, I wish I would have went with the MT357, it just seems like I am not going anywhere.
I have a 5' on my kubota b8200 which is 17hp and it runs fine. But it's front mount. I did not want to be turned around backwards driving in reverse.
I thought about front blower for my tractor....but I do need my bucket at the same time as snow blowing. Thank
I do have a bucket.....and need it during Snow blowing. We get some tall and icy burns up here...along with the road crew adding more stiffer burns. Bucket is a must. Thanks.
Have chains on all fours.....Hilly and flat driveways....Concreat and asphalt driveways from 30ft to 100ft. I have three properties I maintain here. I was just wondering if my 19.3 HP PTO would run a 60" snow blower with enough power. The MT225S has 25.7HP at the engine. Runs great BUT with a bucket full of snow and blowing out the rear ????? Thanks.
/ NEED help !!!! Snow Thrower / Blower #17
My blower book recommends 60 inch blower should have 20 hp tractor so it looks like you made a very good choice.
/ NEED help !!!! Snow Thrower / Blower #18
I need to add my two cents here. Two cents is not worth much these days, so also take my advise with a grain of salt because thats about what two cents will buy ya. There a joke in there somewhere I'm sure.
I have the MK Martin 72in INVERTED snow blower on my 45hp tractor. It works great! However, that blower will bring my tractor to an absolute stop in heavy wet snow. I wear chains and have blown snow off several driveways, all long, all on hills, with all types of materials and in all types of snow and ice. I've even used it to blow the county road last year when a large blizzard came though. Needless to say, I know a thing or two about this whole snow blowing activity.
The thing that I wish I had was more horsepower. My blower will blow snow far enough and high enough to get it completely off the road. Throws typical dry cold snow about 20-25 feet. But that is dry fluffy stuff. When we get that warm snow, or the it snows in the morning hours but warms up during the day above freezing, or turns to rain, or whatever. When the snow gets wet and heavy, I loath blowing snow. That blower will plug up quicker than one can blink! And that is driving slow, the snow is just too heavy. The snow doesn't get blown very far either.
The other thing I do is to either rake the cutting edge back slightly for the first few times of clearing snow, or raise the shoes up a bit. You really want that first layer of snow and ice to form, especially on gravel. Nothing like blowing your gravel driveway into the forest or field. The damage caused by thawed rocks, to the blower and to whatever the rocks might hit, is not fun either.
The weight of the blower is deceptively heavy. In my case, my blower is 685lbs. But the hitch puts that weight pretty far behind the tractor. Not saying my hitch cannot lift it, but I defiantly feel it back there. The blower your looking at is 695lbs on a smaller tractor than mine. Not sure about the length of your hitch, how far away the weight is from the pins, but I would assume since it is more of a conventional drive-in-reverse style, it's closer to the pins.
I don't mean to discourage, just being realistic. If I had to do it over again, I would probably have purchased a larger tractor! 😁
I also did a video of blowing my driveway with my inverted pull-type snow blower. Check it out!
/ NEED help !!!! Snow Thrower / Blower #19
Wow your 72” blower weighs 145 pounds more than my 72” MK Martin blower, I never realized Inverted blowers were so much heavier but I have never seen one in real life.
The only times mine has ever plugged was because of shearing a pin because of rocks-gravel and it was pretty easy to unplug it.
My tractor is a little bigger than yours the PTO is rated at 44 horse power , if the snow is really wet I have to slow down but that’s very easy with hydrostatic transmission, my blower supposedly requires 35 Horse power.
The biggest issue with my blower is the shoes ain’t worth crap for use on gravel, I’m hoping to fix that somehow this winter.
In your case I agree it seems like you should have a bigger tractor.
/ NEED help !!!! Snow Thrower / Blower #20
In very dense drifts, my 5 ft Lorenz blower was needing all the power my NH TC33D tractor could muster and I was barely moving.
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
Bulk Lot - (3) Sticks HDPE Pipe - 24in x 40ft - Selling as One Lot (A63689)
Bulk Lot - (3)...
2017 Ford E-Series FedEx Delivery Truck, 5.4L V8, Step Van Conversion (A63689)
2017 Ford E-Series...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
2020 GMC AT4 CREW CAB TRUCK (A62130)
2020 GMC AT4 CREW...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7866 Miles (A63688)
2019 Cadillac XTS...
