YANMAR Gt14
/ YANMAR Gt14 #1
calmeida131
YANMAR gt14
Looking for mid mount mower deck and any other attachments for a 1989 yanmar gt14. Thanks
/ YANMAR Gt14
/ YANMAR Gt14 #3
Nice looking garden tractor.
/ YANMAR Gt14 #5
Hi calmeida131,
I have a very good Gt14 mower model BM480 that Yanmar made.
Do you have the front PTO on your tractor to power the mower?
I will PM you with more info.
Thanks, Gjamtrac
/ YANMAR Gt14 #8
Hi calmeida131,
Thanks, Gjamtrac
Back when they were new,
/ YANMAR Gt14 #9
Do you know how to open the Private Message I sent?
My mower looks just like the pic that bmaverick posted.
Where are you located?
Can anyone out there help calmeida131 open the PM?
/ YANMAR Gt14 #10
For anyone to open a PM, go to the upper right corner near the ID. Click on the envelope icon.
/ YANMAR Gt14 #11
PT
Yes it does have the mid mount pto
NO Drive shaft? It's has a Mid mount PTO attachment. What's all the Hyd. lines for? Can't say I ever seen that setup. What do call it ?. Model number Size, Specs, Etc.. Do you have a Manual on that site of yours? I'd like to check it out!!
/ YANMAR Gt14 #12
PT
NO Drive shaft? It's has a Mid mount PTO attachment. What's all the Hyd. lines for? Can't say I ever seen that setup. What do call it ?. Model number Size, Specs, Etc.. Do you have a Manual on that site of yours? I'd like to check it out!!View attachment 835760
The mower decks that I have look the same but are belt driven off the front PTO of the tractor.
/ YANMAR Gt14 #13
The pic. of the GT front wasn't showing much of anything but the Typical front axle 2WD setup. I knew about a possible Mid mount and the woods has a Rear PTO setup that drives a Mid Mount. The Hyd. drive is a different setup I've never seen before. Interesting! I'd like to see how they set it up.;)
/ YANMAR Gt14 #14
It appears to have been modified to go on the front of a tractor like the Case/Ingersoll, which had a hydraulic drive mower that went under the belly of their tractors.
If you look at the rear wheels on the mower deck you can see they have been modified to extend rearward and they also caster all the way around.
But the mower deck is a Yanmar BM480.
/ YANMAR Gt14 #15
I drive a FEL. Hyd. pump from the Crank shaft pully with an Adapter. Works really good now I have it up and going. On a ford 2000. Reason why I was curious how they did it. I'm running 2 pumps. PTO and a front driven pump. I figure on that little GT they pretty much had to do the same with it being Hyd..
