Windows Defender reporting TBN as unsafe
   / Windows Defender reporting TBN as unsafe #1
plowhog
Elite Member
North. NV, North. CA
Massey 1710 / 1758, Ventrac 4500Y / TD9
I replaced an aging PC yesterday with a new one.
Since then I periodically get a notice when browsing TBN that the site is unsafe and I should not proceed. It's not happening with any other sites.
   / Windows Defender reporting TBN as unsafe #2
What does it say when you click on "more information"?
   / Windows Defender reporting TBN as unsafe #3
I got this message the other day with an obnoxious alarm. I had to sign out of my laptop to stop it. I had clicked on Amazon prime.
I didn't ask for more information. I considered it an intrusion and just wanted out. Didn't even click OK.
I clicked the back button. Next time I will click more info and see what it says.
   / Windows Defender reporting TBN as unsafe #5
They are right! TBN can get you to spend way more money than you intended on stuff you didn't even know you needed. Probably should have warning labels.
   / Windows Defender reporting TBN as unsafe #7
I've been using Defender for many years and its never had an issue with the TBN site.
   / Windows Defender reporting TBN as unsafe #8
I'd never had a problem with Amazon Prime before either but it did that day. The next day I tried going to the same site and it popped up again. I quit using that entry and access Amazon thru a different portal and don't have any problems.
I'm not clicking on anything once I get that notice. I consider that click bait and put myself at risk. And on my laptop it doesn't even do any good to turn the computer off and back on. Only way I can stop it is to "sign off" and then sign back in. Go figure.....
   / Windows Defender reporting TBN as unsafe #10
Some sites are becoming unusable even from all the ads. The drive is unusable on mobile without ad block
This site isnt too bad but on a computer, ad block is a must have
Dewalt D28493 7/9" Angle Grinder/Sander (A59076)
Dewalt D28493 7/9"...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A56435)
2014 Doyle Dry...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
1325 (A58374)
1325 (A58374)
1459 (A57192)
1459 (A57192)
KMC 70Z7 WHEEL LOADER (A52709)
KMC 70Z7 WHEEL...
