3 Pt hitch jerks, on lifting
/ 3 Pt hitch jerks, on lifting #1
Goat man 75
Maine
Antonio Carraro SRX 8400, 2002
Bought this tractor used 5 years ago and since that time it has had this issue. On lifting the 3 pt hitch arms, with implement attached, the arms jerk up, not all at once but in spurts, which is very hard on the implements. It happens whether I raise the implement slow or fast. Hydraulic fluid is OK. There is no slow motion lift. Lowering the implement is fine and goes evenly with the 3 pt lever. I prefer to do my own repairs. Suggestions to resolve the issue would be greatly appreciated.
/ 3 Pt hitch jerks, on lifting #2
Sounds like a proportioning valve is shot If it ever had one. Some call it an inching valve.
The flow is not being regulated with your pressure orifaces being wide open.
You can fix this by installing a 3 pt proportioning valve on the feed.
Good question on the proportioning valve. I will look into that. Thanks.
2019 FORD F-150 STX CREW CAB TRUCK (A59823)
2019 FORD F-150...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2018 GENIE...
2019 Chevrolet Tahoe SUV (A61569)
2019 Chevrolet...
2016 FORD F-550 SUPER DUTY DUALLY CAB-N-CHASSIS (A60736)
2016 FORD F-550...
2010 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2010 DRAGON 150...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
