MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 67,296
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Had many things going on in evenings, plus plenty tired from work.
Waiting for hydraulic cap and plug set to arrive around 21st of November. I put up some LED lights in the garage and hung one under the canopy to make it nice and bright when work commences. Just cleaning up the gumbo in the engine compartment as time permits.
Once engine tub compartment is cleaned out, I'll use some cardboard to make a template of the engine mount bolt holes in the tub bottom. Then use that to measure up a plate and some square tubing to cut and weld into an engine stand. Then mount it up and figure out how to fire it up. Gonna find an ignition key, wiring socket, etc. to match what's in the machine, and a little battery stand to make it easier. I have several small engines I'd like to work on over the winter.
