   / Your last generator Maintenance Run #6,294
Non ethanol fuel here is $0.60 higher than cheapest ethanol fuel. Actually supreme ethanol is higher than non ethanol here.
   / Your last generator Maintenance Run #6,295
What maintenances do you do on a stored, PTO generator?
check the level and condition of the gearbox oil, lightly lube the pto shaft and scope it in and out.
You may wish to disassemble the housing tins once in awhile and check for insects and other vermin.
   / Your last generator Maintenance Run #6,296
for the little any of us actually run our gasoline gens, I think whatever the bump in cost for E0 is worth it. It stores so much better.
Thank goodness for clean propane.
No E0 anywhere around me in Eastern PA.
I was so spoiled in NC, 93 octane E0, had 22 engines of various sizes to maintain, and that gasoline was wonderful.
biggest problem now is the snowblower. I suppose thankfully it has had little use lately. But with EFI, it starts right up.
   / Your last generator Maintenance Run #6,297
Just wish so could get it...
   / Your last generator Maintenance Run #6,298
I have used Avgas for the last 30 years with excellent results. Fortunately, I have easy access to it.
Haven't followed it lately (non-pilot here), but I thought there was talk of LL going away (?).
Rgds, D.
With you there.....
Kanada..... 2023...... Govt wants to sell me dope, on at least every second street-corner......
..... but if I want Useful Industrial Product <<<<< You need Serious Connections..... and probably will still have to wait....
Rgds, D.
20708 (A55853)
20708 (A55853)
2020 Ford F-350XL (A53314)
2020 Ford F-350XL...
2018 Ford F-250 Reading Enclosed Service Truck (A53422)
2018 Ford F-250...
2010 Astec Underground RT660 4WD Trencher Backhoe (A55787)
2010 Astec...
Metal Peacock Statue (A55758)
Metal Peacock...
2008 Ford Fusion SE Sedan (A54815)
2008 Ford Fusion...
