   / Your last generator Maintenance Run
Did an 18 hour maintenance run on my Predator 3500 inverter yesterday and today because of a power outage. lol
Using a nasty IC engine to stay warm, with Winter coming.... How Dare You !
JK, in case my sense of humour is non-obvious :cool:
I've heard good things about the Predator standard gasoline replacement engines - how do you like that inverter unit (aside from Saving The Day, yesterday !).
Rgds, D.
   / Your last generator Maintenance Run #6,272
Rgds, D.
Ha ha ha!!
I really like this generator, I bought it to power my camper and its super quiet and has been very reliable. For the price I cannot complain.
Ha ha ha!!
Been a while since I looked @ that lineup..... definitely more offerings.
I could see that 5k inverter dual-fuel following me home..... good thing I haven't been to HF in a long time.....
Rgds, D.
   / Your last generator Maintenance Run #6,274
Ran this unit for an hour yesterday after @5 months. Started up with no issues.
   / Your last generator Maintenance Run #6,275
I’d say you’re lucky. Better to run it sooner/oftener if possible. The last thing you want is to find out it wouldn’t run when you need it to. 😉
   / Your last generator Maintenance Run #6,276
I never run mine between emergencies. Stabilizer with any fuel going in, then run fuel tank down low, shut off fuel valve to run the line dry, drain all fluids from carburetor bowl and crank case, refill crank case with fresh oil, and store. Always ready for next time, whether it's 3 weeks or 3 years from now. Just pull it out of storage, fill tank with fresh fuel and stabilizer, open fuel valve and start.
   / Your last generator Maintenance Run #6,277
You’re doing things right for sure. I just got the sense that the previous poster was bragging about how well everything went, with no mention of any kind of plan. See how he exercises that big generator….with a lightbulb?
   / Your last generator Maintenance Run #6,278
Thanks, Rob.
I guess it depends on the type of generator, intended usage, and even climate and where it's stored. I feel my plan is the best for a portable gasoline generator kept in a dry safe place, used only in emergencies, and never sitting more than maybe 3 years. If I had to store it longer, say 5-10 years, then I'd completely drain the fuel tank rather than just draining the carb bowl and trying to leave the tank very low on fuel with stabilizer. If I were storing it outdoors in the rain, or any wet environment, the plan would change again.
It's worth noting that all of us come up with our own plans based more on logic than data. Who has 100 generators running in groups of 10/each under different maintenance plans, over the course of years or decades, to really develop any statistically-valid opinion on what maintenance protocol works best? And as soon as you have good data from such an endeavor, the technology, fuel, or oil types change, invalidating all that hard-won data. :p
   / Your last generator Maintenance Run #6,279
We do have a Eaton branded 20KW whole house generator; this one automatically exercises once a week (also without any load). It did come on about two months ago when we had a power outage for a couple of hours and worked well. The 12K Watt peak and 9.5K Watt continuous rated presently defunct Japanese built Subaru is a highly regarded unit, and is a pure back-up. The check interval was extended this time due to move related issues. Next test will be sometime early 2024. I start is up every couple to three months typically and never had any issues. It is also on a good diet of ethanol free gas.
The last post which alluded to my bragging failed to note that the lamp used was a puny 7 watt equivalent LED bulb. It was turned on and off at @5 min intervals and the idle down feature of the generator worked flawlessly each time the lamp was turned off. The voltage regulation of the generator is exceptional and the "same" puny LED lamp has been utilized mostly when exercising the generator, other than a few occasions where two 1500 watt heaters are plugged in for additional load.
Separately, the generator is equipped the same Yuasa 500 CCA AGM battery I had installed when I purchased the generator in 2017. Due to routine maintenance, I don't typically have issues with my vehicles including lawn/garden and power equipment. They work as intended, touch wood!
Nice wattage/coverage.
Find a protocol that works for you; stay with it till it doesn't.
Gasoline is a big variable. W/O going to racing gas etc, e-free has pretty much been wiped out here, in the last year :((n)
Rgds, D.
(2) SQUIRREL CAGE FANS (A54757)
(2) SQUIRREL CAGE...
New Quick Attach Hay Spear (A54865)
New Quick Attach...
2018 FORREST RIVER CRUISE LITE CAMPER (A53843)
2018 FORREST RIVER...
New Powersmart 4400 Watt Portable Generator (A54865)
New Powersmart...
2022 Polaris Ranger 4x4 Utility Cart (A55851)
2022 Polaris...
2020 John Deere HPX615E Gator 4x4 Utility Cart (A55787)
2020 John Deere...
