dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,685
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
In reading the above, it sure sounds like your 2-spool valves in each armrest have 6 hoses each: IN, OUT, and 4 workports. The one to the tank is clearly OUT, and you have traced the workports to the main valve body, so the one with the filter on it must be the IN from the flow divider at the left end of the main valve.Since one can buy a single spool control that has 3 hoses (two for control and one for return, yes?), I assumed these two spool controls were simply scaled up with two control and return for each spool. Except I didn't expect to see one of the 'returns' from each joystick go thru filter and back to main stack/body.
Yes each joystick (2 functions/ spools each) has a total of 6 small hoses. 1/4 I think. No 'power beyond' unfortunately.
Each spool/function has two hoses going to corresponding control portion of main body; to blocks top and bottom of the main body.
The 'pilot' blocks you can see on top have matches on the bottom also for each pilot function.
That leaves two more hoses for each joystick. I assumed that made for 1 return for each function, like a scaled up single spool remote.
One hose from each joystick does run to tank, but the other one from each goes thru filter and back to main stack near pump inlet.
In the EM15 I opened up, I could not see clearly how the servo joysticks were connected. I did not see those filters at all.
When you buy a run-of-the-mill 2-spool open center valve, for some common application (like an AUX valve for your tractor), it will often be a "monoblock" valve. The IN and OUT plumbing for each spool will be handled by a single port for the whole valve, and connections to each spool will be done internally.
