2manyrocks
Super Member
- Joined
- Jul 28, 2007
- Messages
- 8,650
Revenue enhancement ..... like those ticket generating traffic cams.
Easy to do I have a camera and monitor for one of my tractors, the camera is on a magnetic mount and has a battery pack that is also magnetic. Easy to put the camera anywhere.That back-up camera is a godsend for anyone who routinely changes trailers. Other than bad weather, my pickup is used primarily for towing my three trailers, and I still get giddy every time I back up to a ball hitch and don't have to do that old routine of jumping in and out of the truck 6 times to line it up. Some trailers are just too heavy to move to the ball, if you're off more than 1/2".
I wish I had a camera on the back of the ballast box on my tractor, as I often mount a hitch there, and it's just barely out of view from my seat. Usually takes me 2-3 times on/off the tractor to line that one up under a trailer, as the little bit of sway in the trailing arms and hydraulic top link can help fine-tune position if you get it close enough.
Don't really see the need for it with an automatic. Then again, I generally use my left foot for the brake. Maybe handy if it's a stick shift and it's an unfamiliar vehicle where the clutch may engage at an odd spot or if you're just learning to drive manual.On most of my cars, there's a "rollback control" option, or some similar names. Seems to hold the vehicle static on a hill, as you transition from brake to accelerator, with auto trans.
Don't have that problem on my tractor, but it can be a PITA to line up the hitch on my ATV. It's underneath the back cargo platform, recessed about a foot. No way you can see it while on the quad.I wish I had a camera on the back of the ballast box on my tractor, as I often mount a hitch there, and it's just barely out of view from my seat. Usually takes me 2-3 times on/off the tractor to line that one up under a trailer, as the little bit of sway in the trailing arms and hydraulic top link can help fine-tune position if you get it close enough.
Same here. Don't need an exact temperature maintained. Seems like in the spring/fall it would go back & forth between heat & AC to maintain. I'm all for simple, easy to use controls.I hate the modern climate controls; this truck has the dials that I can be in a completely dark truck and just by feel I can tell what setting it's on and adjust it how I want without taking my eyes off the road. I abhor the idea of this being on a touch screen, it's bad enough in a modern car that you have to actually set a particular temperature (when I get in a cold car - bake me for a while. once I've warmed up, I want it cooler. Seems like I adjust the temp in my wife's car with its auto control more often than in the truck but I'm more comfortable in the truck)
If you have a big farm, you might be able to sneak it in for off road use only.Wonder what it would take to buy one in Mexico, bring to US?
$10K...I'd buy one.
In Mexico we saw ITALIKA motorcycles in a huge store like Costco, 250cc for $1,400. I would have bought two if I had rented a van. No room in the SUV.
For off-roading the Toyota might be OK. Not a huge engine, but how big do you really need? The older compact Toyotas were quite popular off roaders with a few modsSeems a bare bones $10k pickup would be a lot better than something like a Roxur at $15k+. My Kawaski Mule was just over $8k and I would rather have this Toyota for a couple of thousand more. Bring it in as a UTV and avoid all the safety BS.
