Ever break a tap?
/ Ever break a tap? #1
gstrom99
Elite Member
Butler County, Iowa
Deere 855, Deere 530R zero turn, Allis Chalmers D17 III, Polaris Ranger, Deere 3032E (SIL's), Yamaha Timberwolf 250, Husky saws, H & H 10k and Carry-On trailers
It's not on a tractor, but...
I finally got my two post car lift installed and started to wire it. I wanted a "motor disconnect", so I needed to attach that box to the column. The installer advised that nothing can protrude inside the column where the lift pads run, and don't bother trying any "self tapper screws" - they'll just break off. So, I drilled and started to tap threads for 1/4" short bolts. I got one done, and on the second one, the tap broke when almost through. I think I ordered a good extractor from McMaster Carr: McMaster-Carr should be here tomorrow.
It's easy access. How successful are these tools?
/ Ever break a tap? #2
They do work...on straight flute taps. Get the ones that match how many flutes you have. If you start to bend the prongs, lightly tapping the broken piece this way and that way first with a small punch may loosen it enough. Keep the extractor as close to the broken tap piece so the prongs are the strongest.
/ Ever break a tap? #4
depends on how heavy handed you are and next time drill the hole one drill size larger than the specified tap drill. as what you are attaching isn't holding any weight or providing support. Taps wear out and then the force to drive them overcomes the strength of the tap and then they break and use some lubricant as well. any light oil is just fine and when hand tapping, screw the tap in a full turn and back it of 1/2 turn to break the chip the tap is cutting. Full turn, 1/2 turn and repeat.
/ Ever break a tap? #7
Spiral flute taps are more of machine taps than hand taps. I use them all the time when semi production tapping. Broke a few of them as well. Sometimes I'd like to have a wire EDM machine to remove them without scrapping the piece.
/ Ever break a tap? #12
I welded everything to my 2 post lift. Well, I welded unistrut to the lift frame and attached everything to it. I mounted underneath facing lighting with the control box as well as the controls for the lift. Put my contactor for the lift motor on the frame as well.
/ Ever break a tap? #13
If you're not already using it, a good cutting fluid can make a world of difference.
Note cutting fluid, not lubricating oil. Cutting fluid is designed to bring metals together, not keep them apart like lubricating oil
/ Ever break a tap?
Thanks for all the input. I thought about welding nuts to the column, but it's soo damn pretty, I'd hate to disturb that...
I'm expecting the extractor tomorrow, via UPS.
/ Ever break a tap? #15
Have you seen these?
/ Ever break a tap? #16
Broke plenty. Several methods to remove and its a case by case basis.
/ Ever break a tap? #18
In my unfortunate experience with breaking taps sometimes easy outs I've used are somewhat brittle so I've used a needle punch to break them out, sometimes mangling hole but most of the time fortunate to be able to use a bigger size, or in other cases fill hole by welding and repeat with successful results. I do keep a printed chart taped to drawer with tap sizes with recommended hole size to drill. I also use oatey brand it's the thicker viscosity dark cutting and tapping fluid with good results and it's readily available almost everywhere I frequent.
/ Ever break a tap?
What a great idea! I can't read the drill sizes laser printed(?) on these "new" taps.
/ Ever break a tap? #20
I keep my cobalt bits in a index with sizes clearly marked on it, also have a cheap easy to read caliper lying around close by. Also fortunate to have a big enough tool chest where I can keep my tap and dies in there case which is also clearly marked. Nothing's more frustrating than not putting my tools back and keeping them organized. Until a few yrs ago screwed up a few tap projects cuz I didn't fully understand letter sizes.
2023 VOLVO L90H WHEEL LOADER (A64279)
2023 VOLVO L90H...
Tropic Trailer 18ft T/A Flatbed Equipment Trailer (A64553)
Tropic Trailer...
2020 CATERPILLAR M320F MOBILE EXCAVATOR (A65056)
2020 CATERPILLAR...
2006 International 4200 2,000 Gallon Water Truck (A64553)
2006 International...
2011 Chevrolet Express 2500 Cargo Van (A66736)
2011 Chevrolet...
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
