2305 tie rod
/ 2305 tie rod #1
Wvanatti
John Deere 2305 (2010)
While putting new tires on my 2010-2305, noticed the right side tie rod ball is sloppy ( left still tight ). I just looked on Green Farm. List for $602
LVA803708
Has anyone ever replaced or even repaired ? Maybe a cheaper source.
It drives like new, never would have noticed except mounting tire and felt the slop. Thanks much for any insight or response. Bill
/ 2305 tie rod #2
Can you identify which part is worn to make it sloppy, or is it maybe just loose and needs tightening?
Has it missed the grease routine?
Think I'd see if it could be tightened, and then just use it until too loose to tolerate any longer, then get a new one if aftermarket cannot be found.
/ 2305 tie rod
Thanks for the reply. I’ve greased all fittings every other mowing. It has mowed pretty much level ground since new. I didn’t remove cotter pin and see if nut would tighten. I’ll do that this weekend, but I’m assuming it’s just wore out at the ball. It was just a fluke that I caught it. With the front right tire jacked up, noticed it moved in and out maybe a 1/4”. Looked down at the rod and seen the play was under the boot. I sure had sticker shock when I seen the price. I’ve keep up on preventative mx to a point of overkill. I’m betting I can find a tie rod at local parts store, cut old one off and mig weld it on. Guess I never noticed before that there is zero adjustment. Mostly the post was to see if anyone else had a solution. Figured no need reinventing . I’ll follow up on my post with my fix eventually. Thanks again.
/ 2305 tie rod #4
I had to replace a tie Rod end on 4720 I use to have.
It only had 400hrs & was extremely loose.
/ 2305 tie rod #5
Hopefully your issue is in the ball joint itself where you can weld in a replacement. 1/4" is a lot of movement for a single ball joint.
Hopefully the tapered seat in the knuckle is not wallowed out like a much older/higher hour tractor I repaired recently. The tapered seat part that bolted to the knuckle was unobtainium so I had to bore out and weld in a tapered bushing I machined for the purpose
/ 2305 tie rod
Thanks for the photos an input. Haven’t been able to look at it yet, but I’m thinking I’ll go simple and cut it off, weld a new one on. Just don’t understand why the right one went bad and not the left. Maybe constantly making left turns puts extra force on the right one causing the issue.
/ 2305 tie rod #7
Would help to see just what is worn out, that makes it loose. Then decide on a fix.. just sayin.
/ 2305 tie rod
I’ll try to post a video tomorrow. I went and looked at it again tonight. Now have a better understanding and a plan. #1 in the diagram is the complete assembly. A tie rod has been welded on at each end. The bar appears to be hollow. So I’m pretty sure I can grind off the welds and pull it out of the pipe. Match one at auto parts store and re weld.
/ 2305 tie rod
/ 2305 tie rod
Tried to upload video from iPhone. Some reason the app wouldn’t take it. The arrow points to the part that’s worn out. Bottom part of tie rod is the part that moves 1/4” back n forth.
/ 2305 tie rod #12
Before cutting the end off, see if you could remove the tie rod and lay it on something solid. Then take a punch and ping around the outside of the ball socket. This will tighten up the top and prevent the ball from coming out of the socket. Put the tie rod back on and continue mowing.
/ 2305 tie rod
Interesting. Thanks for that. Great idea. I’ve done that to bearing spindle caps to make them stay one. I’ll certainly try that.
/ 2305 tie rod
/ 2305 tie rod
Thanks very much for the idea. I took it off, heated it with acetylene torch, put in my pipe vise and crimped all around it. Tight now. Zero play. Whew
/ 2305 tie rod #16
Great news. (y)
/ 2305 tie rod #17
Does it have a grease fitting ?
Keep us posted if it stays tight
/ 2305 tie rod #18
Most don't have a grease fitting. I have a electric chainsaw I have to oil the chain on. I occasionally give the tie road ends a shot of bar and chain lube on my JD mower.
/ 2305 tie rod #19
Glad this worked for your slow speed application, but I certainly wouldn't want to take a torch to heat treated steering components for any high speed application where failure could lead to catastrophic consequences like rolling the vehicle
/ 2305 tie rod
Yes, thought about that. Knew it would take the temper out, but nothing to loose. If it spreads again I’ll weld a new one on it.
2006 CATERPILLAR 307C EXCAVATOR (A63276)
2006 CATERPILLAR...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
2016 KUBOTA SVL90 SKID STEER (A65053)
2016 KUBOTA SVL90...
2012 Freightliner FLD120 Ambulance (A64556)
2012 Freightliner...
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
44in Single Cylinder Grapple Bucket Skid Steer Attachment (A64553)
44in Single...
