Rotary cutter gear box - oil drain plug question
   / Rotary cutter gear box - oil drain plug question #1
adlertom
Southern Wisconsin
New Holland TC33DA hydro w/supersteer
Land Pride RCR 1860 rotary cutter. Why is there a small hex socket INSIDE the larger hex socket on the gear box oil drain plug?
   / Rotary cutter gear box - oil drain plug question #2
That's just part of the manufacturing process, in this case rotary broaching. When cutting the hex, it pushes the material in and creates like a small hex inside.
They could go with a drill after the fact to clean it out and make it look better but that costs money and at the end of the day, that's just a simple drain plug.
Interesting, thank you.
   / Rotary cutter gear box - oil drain plug question #4
Interesting. 👍
It could also be used as a backup (by me) after I stripped the other one when trying to remove. 😆
2018 INTERNATIONAL LT625 SLEEPER (A51219)
2018 INTERNATIONAL...
2017 Schulte FX107 84in Rotary Cutter Attachment (A50322)
2017 Schulte FX107...
1969 JOHNSON J25 GOOSENECK TRAILER (A51222)
1969 JOHNSON J25...
1266 (A50490)
1266 (A50490)
JCB 3TS 8T SKID LOADER (A51242)
JCB 3TS 8T SKID...
Fire Place Mantel (A49462)
Fire Place Mantel...
