TC30 Starting Problem
/ TC30 Starting Problem #1
jn9230
Member
NH TC30
2008 NH TC30, 670 hours.
I wonder if someone could verify something for me:
I believe I have detected a short in the electrical system, but I need help to verify. This TC30 has fallen victim of the no-start issue discussed for other NH and DX tractors.
So here is my question: When I disconnect the negative battery cable, I get continuity between the positive battery post and a known good ground point on the firewall. This seems incorrect to me, and an indication I have a dead short somewhere. Can someone verify if this for me?
There seems to be a slight draw (.2v) on the battery when connected properly (12.5 volts at battery posts). Trying to diagnose, I find that when I pull fuse #1 (5A to Safety Controller and Park Brake switch), the draw goes away (12.7 volts at battery posts). This could be enough to drain the battery.
Related info:
  • Tractor has been garage kept its entire life, never left outside in rain or harsh conditions, never mistreated. Has had regular maintenance. Has been reliable until one day a month ago it just quit out in the field.
  • Tractor will not start or even turn over.
  • New battery – 1 month old, 12.7 volts.
  • Added starter solenoid relay modification as discussed in TC33D won’t start thread.
  • Fuel solenoid tested good, with 12+ volts. Cleaned connects best as I could.
  • Good fuel at fuel bleeder point (have not checked for fuel at injectors).
  • No blown fuses. Cleaned and re-seated all fuses.
  • Tested parking brake safety switch with Ohm meter, tested good.
  • Tested seat safety switch with Ohm meter, tested good.
  • All wires appear to be intact, no critter damage, fraying or corrosion anywhere.
  • Voltage and Ohms checked both positive and negative battery cables on and off the tractor. Cleaned both ends and made shiny off the tractor. Applied dielectric grease where appropriate. Both cables tested good with perfect continuity. No damage. 12.5+ voltage at starter solenoid.
  • PTO and Neutral safety switch not tested, but visually appear to be in perfect condition, no damage or wear and tear, rubber protector in perfect condition. PTO switch believed to be good because dash light comes on when PTO is engaged, and goes out when disengaged.
  • Removed the ignition switch and Ohms tested all contacts to appropriate connecters with key in STOP/RUN/START positions. Seems to be working as it should.
I am at a loss. I’ve spent hours trying to diagnose this, and am at my wits-end. I don’t know what else to check or test. Please help!
UPDATE:
After doing all of the above, I decided to quit until I can determine next steps. So I pulled fuse #1 (so to stop any power draw) and put the 12v charger on the battery. I then sat down to type up the above.
After 3 hours, I went back out and reinserted the fuse, and the tractor started right up instantly, no hesitation at all. I ran it at various RPMs for over an hour and it never hesitated. It ran perfectly. Thought I was done, but also thought the true test would be if it started up again. When I shutdown and tried to restart, it would not even turn over; even with the charger still connected. I could hear the fuel solenoid engage, but not the starter solenoid.
Battery had 12.5+ volts when not running and 14.5+ volts as it was running, so I believe the alternator is working.
I’m still a little suspicious of the key switch, and possibly the starter relay modification (although I followed the directions clearly).
I’m totally baffled now…please help, and thank you.
/ TC30 Starting Problem #2
Does it start when you jump starter
Seriously some systems need 12 volts at starter solenoid do you have that with key if it starts everytime jumping it check voltage from key and all neutral start switches a safety switch with corrosion or high resistance can make something not work properly
It started 1 time with the battery charger on it, but would not start again. It does not start every time when jumped.
I had 12.5+ volts at the starter solenoid.
I checked the seat and brake switches with an ohm meter, seems to be working fine.
Just checked the fusible link wire, and it is good.
Thx.
/ TC30 Starting Problem #4
The ignistion switches are not the greatest and I would suspect it. If it won't start, try jumping at the small tang on top of the starter solenoid to establish that everything there is good. Then work your way to the starter relay mod and so on.
/ TC30 Starting Problem #5
Thx.
Intermittent electrical problems like this can be very time consuming to fix. You really need to be ready with the time and tools to check circuits every time you go to touch the machine.
To seriously cut down on your diag time I would make up a jumper wire for each safety switch and put them in. If the machine never has a problem again you know it's one of the switches. If it does have the problem again then it may be your key switch.
Did you check the neutral and PTO switches?
Did not check neutral and PTO switches, but...
  • PTO switch seemed to be working because dash PTO light comes on when engaged and off when disengaged.
  • Both PTO and neutral switches visually checked perfect. No damage, tampering, or disturbance of any kind, and also rubber dust covers where in perfect, like new condition, so I thought both switches would be fine.
However, I will take your advice and make jumpers for all four and eliminate them. Will try to get that done today and will start the hunt for a new or crossover ignition/key switch.
Thanks much for your input, I will update when I know more.
UPDATE:
Ohms checked all safety switches. All are working. Placed jumpers on all four anyway. No change (no start).
Bypassed first the negative battery cable by disconnecting it, and then adding my own separate cable from neg. terminal post to frame ground. Ohms tested perfect. No start.
Then bypassed the positive battery cable by disconnecting it, and adding my own separate cable from the pos. terminal post to the starter solenoid. Ohms tested perfect. No start.
I now suspect the ignition key switch or the safety control module. Both are expensive but it looks like I'm running out of options. Gonna have to bite the bullet I think.
Still would like to ask if someone with a TC30 could test if there is voltage from the positive battery terminal to frame-ground. I'm getting about 1/2 volt, and I think this is not normal and an indication of a short somewhere.
Thanks much.
/ TC30 Starting Problem #8
I completely understand this feeling... "I'm pretty sure I know the way it should be, but..." That's a good diagnostic mentality! I have a TC29DA and I tried to recreate your test. I keep the battery on a tender, but removed it first. After that, and throughout, the battery read 12.86V from '+' to '-' terminal.
I removed the '-' battery cable and measured the voltage at that '-' cable (so essentially, frame ground). We think zero, right?... It was 5.9V and falling very slowly (in the 0.001V digit)! I'll provide some interpretation on this in a minute (which is perhaps better than wild speculation). This was done with the key switch in the OFF position.
I turned the key switch to the RUN position and measured the same voltage at the '-' cable (still disconnected from the battery terminal) and it read flat zero, as we would expect, right?
I turned the key switch back to the OFF position and now it read about 5.6V and rising slowly. I went back and forth with all this and found it all fairly repeatable.
Strange, right? How can one read any nonzero voltage in two points in an open circuit? My suspicion is that there is some component in the system with a capacitive characteristic storing some charge for "awhile". I left the '-' cable disconnected and I'll measure it again in the morning to see if that "residual voltage has dissipated". But again, those nonzero measurements were in the OFF position. It was definitely zero in RUN.
I'm interested in exactly what you mean by this. So you jumped +12V to the spade terminal on the starter solenoid and that works sometimes? At this point I think you just have a bad starter, but I'm surprised this wasn't commented on before.
The key switches on these are known to be "not great". That could certainly be a contributing factor (or THE problem), but the info above does not jive with that for me. Still replacing it is not money wasted, even if the problem is not resolved. I replaced mine with a NAPA part that others on here suggested. I'm sure it's both better and cheaper. This is it:
/ TC30 Starting Problem #9
What voltage do you have while cranking the starter? I had a starting issue with my NH 1530 and finally bought a new battery. I've been running the new battery for about 5 years now and no more issues. I have replaced the key switch on it about 15 years ago.
/ TC30 Starting Problem #10
Update from my post last night: That voltage reading in the OFF position dropped more (it's a really slow drain) to about 4.2V. Battery voltage post-to-post was now 12.84V.
My current thought is that your 0.5V drain is a red herring. With a good battery and good cables connected to starter and ground, a 12V signal to the starter solenoid should energize the starter motor. Failing that, we need to look at the battery, the cables, and the starter motor itself.
Battery: Good suggestion from Iman, but you said the battery was new. Nevertheless, good to check that voltage reading. Mine is a little above 10V while cranking. Could also try jumping in another good battery to check.
Cables: These forums present examples of where these NH cables (especially) pass a resistance test, but because of internal corrosion, cannot carry the current to power the starter. I'd use a pair of jumper cables: '-' to frame ground, and '+' to the high-current terminal of the starter (careful not to ground out!) to provide a parallel pathway for current to get around a potentially bad cable. I suspect bad cables would also show a low voltage across the battery while cranking.
Starter: Failing all else, replace or rebuild. I know I've seen "failed starter" posts on here, so check those first before biting the bullet!
The intermittent nature of your problem may suggest cables or starter over the battery.
One more thought on the 0.5V measurement: It could be a parasitic loss that would eventually drain the battery to where it's insufficient to start the tractor. But if you keep a tender on it, I suspect it would never be an issue. Good luck!
Follow-up:
6+ months and still no start.
I purchased a new battery. I disconnect it when not working on the tractor for longer periods of time, so not to be a victim of parasitic drain. I also keep a battery tender on it so not to discharge a brand new battery. Voltage seems good when I check it. All fuses good.
I parallelled the battery cables from (-) to frame ground and (+) to starter. Still, engine turn-over is intermittent. I have checked and double checked all the safety switches.
Now the glow-plug light stopped illuminating when trying to start. Engine does not turn over.
I would like to know if anyone has a pin-out, or continuity bench-check procedure for the key-switch (in each key-switch position). I would just replace the key-switch all together, but I cannot seem to find a cross-referenced key-switch from an auto parts store. I cannot seem to find a replacement key-switch.
Finally, I suspect the safety controller module is bad. There is no way to test it, and nowhere to buy a cross-referenced part that I know of. I sure hate to pay NH $550-$600, and I don't even know for sure if this is what's wrong.
Can anyone help me please? Thank you in advance.
/ TC30 Starting Problem #12
Take a look at these TBN posts:
/ TC30 Starting Problem #13
How dedicated are you to factory OEM wiring/components with all safeties in effect? If that's a priority for you I will respectfully butt out. I tend to work around certain items I disagree with in order to simplify things but still get the job done. I find that many times people just want the damn thing to start and run.
/ TC30 Starting Problem #15
I would hope that after 6 months of a tractor not starting that he wouldnt be to attached to all the safety components..at least jump around them for diag purposes.
For the ignition pin out.. you dont really need that. Power in, power out. It's a simple switch. My ignition switch did have loose burnt terminals (tc40). I was able to clean them up and it fixed my starting/glow plug problem. Every thing worked fine for a few months now my glow plug light dosnt work but the glow plugs still work. Not something I'm in a rush to repair as the next fix will be just a large push button directly to the glow plugs. No extra components like a timer and I dont have to run the power through the ignition switch.
Thanks for your post. I am not married to factory OEM wiring/components. Safety switches are easy to bypass when necessary, so I don't mind keeping them in place. I prefer simplicity, and seriously suspect the electronic safety controller.
/ TC30 Starting Problem #17
The wiring diagram I saw doesn't show a dedicated safety controller. It's mainly a series of switches, relays, and a seat safety switch timer. (whatever that is)
/ TC30 Starting Problem #18
Maybe referring to #44, Seat Switch Timer, which I would figure out how to eliminate.
/ TC30 Starting Problem #19
Well as I see it on the diagram I'm looking at the start relay is grounded through all the safety circuits. The relay has a four pin connector with a black and white, a black and red, a white and black, and a yellow and black. The white and black is the ground wire. I would try skinning back some insulation off the white and black wire, attaching a jumper wire from there to ground and see if the starter will operate. If it does, then the relay, key switch, and related circuits are working. Back to the safety crap.
/ TC30 Starting Problem #20
If your ignition switch has a connector labeled as any in the attached it may help for testing. NAPA sells a much more beefy switch. I replaced my TC33D OEM switch which had melted with a NAPA and have not had any problem since 15+ years now.
  • Ignition Switch.pdf
2011 Ford F350 Service Truck (A63116)
2011 Ford F350...
2006 KOMATSU PC300LC-7 EXCAVATOR (A62129)
2006 KOMATSU...
(INOP) NISSAN MU1F2A25LV WAREHOUSE FORKLIFT (A62130)
(INOP) NISSAN...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
1999 INTERNATIONAL 4700LPX 4X2 BOX TRUCK (A59908)
1999 INTERNATIONAL...
2005 KENWORTH T800 T/A 6X4 DAY CAB TRUCK TRACTOR (A59908)
2005 KENWORTH T800...
