/ PTO on 8N won’t attach to mower shaft. My 8N PTO has a kind of slight flange around it that keeps the u-joint from sliding on enough to engage the
#21
LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,194
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
It doesn't take much misalignment to have the extension being the tail wagging the dog. Also depending on the type of PTO driveline the extension can act much like a drawbar is set to short and a multiple piece shaft can get into harmonics when turning under load, such as a forage chopper under load while making a turn.Interesting comment Lou.. The shaft extender I have is split with a hex cap screw so you can actually clamp it tight to the stub and eliminate any vibration / slop.
Also, I had to use an extension on a dual pto tractor for a hydraulic pump because it wouldn't clear the 1000 rpm shaft without the extension. When that pump got under a irregular load the pulsing would get everything to vibrating. That lead to a broken tractor pto stub which was a bit expensive to repair.
