Mouth Taping, Anyone Else Doing It?
/ Mouth Taping, Anyone Else Doing It?
Here is an interesting video from an ENT Doctor:
/ Mouth Taping, Anyone Else Doing It? #23
When the electric goes out I wake up real quick with no pressure.
Plug your CPAP into an uninterrupted power supply (UPS).
Check the watts, be sure to buy one large enough.
/ Mouth Taping, Anyone Else Doing It? #24
I thought about taping my mouth shut a while back, but with a mustache and beard, I don't think that will work. Also thought about a chin strap, but haven't seen one I like.
I keep an no-spill insulated cup full of ice water on the night stand, and when I wake up with a dry mouth, I take a quick sip and go right back to sleep.
My house guest says I don't snore as much as before I recently lost about 40 pounds, so that's good.
It will work. At least it works with my mustache and beard.
The roll of tape is one inch wide. Now I cut a piece 1/2 inch long, put it centered on my upper lip just under the mustache. It goes down 1/2 inch covering my lower lip.
/ Mouth Taping, Anyone Else Doing It? #26
I start the night breathing thru my nose. By morning I'm breathing thru my mouth. My nose gets plugged and mouth breathing becomes critical.
Both Brownie and I occasionally snore. So far - it's not a problem for either of us.
/ Mouth Taping, Anyone Else Doing It? #27
Over the years, I've found that putting the wife's thong around my head with the elastic band going under my jaw and up over my forehead is an awesome compromise. Plus, she agrees that it's a potentially life saving move on her part. She get's something out of it too: a good, sound, deep sleep.
/ Mouth Taping, Anyone Else Doing It? #28
I think we're going to need some pictures, to follow this description. I wouldn't want to get it wrong, you know...
/ Mouth Taping, Anyone Else Doing It? #29
Is she still in the thong? Just asking for clarification. Jon
Last night I took a picture of my mouth taped, ready for bed:
This morning's picture of the tape after I took it off:
I didn't get a straight cut off of the roll. Left side measured 1/2 inch. Right side 5/8.
3/8 straight across is the minimum that works for me.
/ Mouth Taping, Anyone Else Doing It? #31
I've been on Bi-pap for years (higher pressure than cpap).
First time using it was like a switch got flipped. I woke up realizing how badly I had been sleeping since my late teens (59 now).
Sometimes, sleeping in a certain position, I wake up dry as hell because the machine blows out through the mouth, Haven't lost any teeth yet because
of it. Luckily.
You need about 4 hours of restorative sleep per night. After my first sleep test the Dr. said I was getting about 45 minutes of restorative sleep a night.
A frightening number to him.
My last sleep test about 7 years ago the Dr. told me don't ever sleep without the machine. It could be fatal several different ways. Heart attack, stroke, etc. caused by apnea.
All this to say, OP have you ever considered getting a sleep study done to assess a better treatment than tape?
It's not an attractive thing to wear at night, especially if it's your first "sleepover" with a new woman, but in the end the machines are almost completely silent, and it was
a life changer for me.
/ Mouth Taping, Anyone Else Doing It? #33
This is easily the strangest thread I have read, on this forum.
Put some digidamitous earth in your mouth tape it shut and you will wake up with all your issues cured or you won't wake up. Either way no more worries;)lol
Did the sleep study about 30 years ago. Put me on a CPAP machine.
Several years later quit the CPAP after had this done: (Uvulopalatopharyngoplasty (UPPP) is a procedure used to remove excess tissue in the throat to widen the airway. This sometimes can allow air to move through the throat more easily when you breathe, reducing snoring)
Subsequent sleep studies showed I didn't have sleep apnea. No snoring but mouth came open and dried it out.
With mouth taping no more dry mouth and better sleep now.
/ Mouth Taping, Anyone Else Doing It? #37
The title sure didn't result in what I thought it was
My first thought was "Your a brave man Charlie brown"
If I tried taping my wife's mouth, I would end up in the hospital
/ Mouth Taping, Anyone Else Doing It? #40
Never heard of using tape at night. I also use a CPAP (10+ years), with nasal pillows. It somehow forces me to keep my mouth shut, while in use.
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
Club Car (A59231)
Club Car (A59231)
2008 Genie AWP-30 Single Manlift (A61572)
2008 Genie AWP-30...
JOHN DEERE 606C - 6R30" CORN HEAD (A64277)
JOHN DEERE 606C -...
(INOP)1989 NISSAN D21 EXTENDED CAB TRUCK (A64280)
(INOP)1989 NISSAN...
2016 WESTERN STAR 5700 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2016 WESTERN STAR...
