Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #22,471
You know what'd you like RBC. On You Tube, there is a guy building a log cabin from dead scratch. Although there are several of these, this guy is the one pictured where there is a roof support cantilevered off the main cabin.
It's a rather long vid but to see what he comes up with to mount the heavy wall logs is rather astounding.
watch
Fascinating arrow !! I enjoyed every minute and a nice rainy afternoon to watch. That guy sure is steady with his scribe and saw. There is a cabin a couple miles from here built like that now I know what it takes. I have worked on a couple of those kits with the 3 flat planed sides and the splines between the tiers - no craftsmanship required compared to what that guy demonstrated. Thanks for posting !!
gg
   / Tractors and wood! Show your pics #22,472
gg
I know!!. That crane thingy he built was truly amazing on how he constructed it.
I also built my own from a kit as well and first went out to Idaho in 1972 with a crew to build one on a mountain side.
I hope to never unsee the majestic panorama I saw in Idaho.
Cheez. From 1970 to now, is like from 1918 to 1970.
That's kinda sobering and depressing all at the same time.
   / Tractors and wood! Show your pics #22,473
I split some more wood today, it’s hickory and is very knot filled and stringy. I’m glad for the hydraulic splitter. Just a very wild estimate but between cutting the tree down, cutting into length, splitting and stacking I’ll have 30 hours in it, roughly a chord when I’m done, maybe a little less.
   / Tractors and wood! Show your pics #22,474
If you have to use much pressure, it's probably time to replace your file. (One of the quickest ways to dull a file is back-dragging it. Make sure you lift it off the tooth when returning the file for the next stroke.)
I'm not really sure how to describe the pressure I use. Much more like brushing my teeth than like scrubbing out pot with cooked-on crud.
I need to get a good file set up for sharpening my chains, what do you recommend
   / Tractors and wood! Show your pics #22,477
I use Save Edge files. I've been very happy with them.
   / Tractors and wood! Show your pics #22,478
I got this kit when I bought my first Stihl saw several years ago, they still sell it. The top is the file in a guide. The thing in the middle is a gauge, I just use it to check the raker height. The bottom one is a file for lowering the rakers. New files are maybe $2 each for Stihl ones or a little more.
   / Tractors and wood! Show your pics #22,479
This is a great kit.
We sell alot of these at the shop.
These are made for Stihl by the Swiss company Valorbe.
Whatever files a person uses, a file card or even a stiff tooth brush is essential for top cutting performance of the file..
   / Tractors and wood! Show your pics #22,480
That is a good guide set and another good one is the Husqvarna roller guide. The reason I like it better is that I can see what is going on at the tooth - seems to help me.
gg
2023 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2023 Ford F-150...
2006 GMC C8500 Altec AM547 50ft Material Handling Insulated Bucket Truck (A50323)
2006 GMC C8500...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
Komatsu Pc200lc Excavator (A50514)
Komatsu Pc200lc...
2016 CATERPILLAR 262D WHEELED SKID STEER (A51242)
2016 CATERPILLAR...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52128)
2007 Freightliner...
