Power track PT400
/ Power track PT400 #21
/ Power track PT400 #22
Looks like this. Can it be rebuilt? My husband said bearings needed replaced.
/ Power track PT400 #23
Yes it could be rebuilt, depending on the condition of the shaft and impeller. If it has a carbon-ceramic (mechanical) seal, that may still be in good enough condition to not warrant replacement. Bearings are readily available through any good bearing supplier. Bearings are just bearings, tractor companies don't make bearings.
/ Power track PT400 #24
Already located bearings and shaft is good. Only need rubber seal
/ Power track PT400 #27
PM me your email addy and I'll shoot you the manuals.
Hello Bob, I have read alot of your messages and wanted to reach out for help as I felt you are so knowledgeable about these tractors. I have a PT400 and the left brack doesn't work I removed the plate to inspect but it seems to be operational but perhaps the brakes lining is worn and needs replaced, I continued to remove more items including the pump under the seat as the gasket had been leaking and water go into the fluid, I'm removing the fluid today and wanted to pull the brake lining circle bands off to inspect, I have a good auto mechanical knowledge but not on this, I have an old 1700 mustang skid steer also that I had learned about had on, do you have any advise or the manual for removal of the brakes, and is the fluid a certain weight of fluid to use thanks in advance for any help.
/ Power track PT400 #28
Nice picture. Sorry, there are no service manuals available for these machines except for what help is in the owners manual. Have you tried to adjust the brake? The procedure is outlined in the manual. You can't remove and install the bands through the top, you have to remove the final drive to get access. Also, if any oil gets on the friction surfaces of the brake bands they will become useless and need to be replaced. There are drain plugs under the steering compartment, so you might want to check that.
/ Power track PT400 #29
Forgot to mention that item #7 is the dipstick, and that the transmission and bevel gear case share a common sump. If I remember correctly it takes around five gallons of 85W-90 GEAR OIL, not tractor fluid or hydraulic oil.
Hi Bob,
I have the same problem described about the pt400 not going into forward or reverse. I ran it to park and give a it good pressure wash. Turned it on and no forward or reverse. Hydraulics still work fine for the plow.
Pto doesn’t seem to engage now. It kind of was, but was very weak. Now it won’t engage at all .
/ Power track PT400 #30
I may have a chance to purchase a Taylor Td 252 and the current owner says that it needs an injection pump. Are these available to buy anywhere?
/ Power track PT400 #31
Built by Guilin in the '70's, later acquired by Yuchai. Does your machine have a shuttle clutch? I have some manuals for the Yuchai machine with the TY395E engine. Machines are very similar, if not identical. You might already be aware that there are no service or shop manuals for these machines, only owner's and parts manuals, but they are a big help.
Hey Bob,
My husband recently purchased a power track 450LT dozer. He seen your threads when trying to find parts or manuals and we are hoping you can help us figure out how to get any diagrams of the dozer. Thank you for your time
2250' of 5" Tile (A66408)
2250' of 5" Tile...
2022 JOHN DEERE 350G LC EXCAVATOR (A65053)
2022 JOHN DEERE...
(2) 10ft Nesting Boxes (A65579)
(2) 10ft Nesting...
2015 International DuraStar 4300 Elgin Broom Bear Street Sweeper Truck (A64556)
2015 International...
2018 Freightliner M2 106 20Ft. Reefer Box Truck (A64194)
2018 Freightliner...
New 2x27 Ratchet Strap (A65579)
New 2x27 Ratchet...
