Kubota LX4020 Already Having Problems
/ Kubota LX4020 Already Having Problems
Different tastes I guess. I wouldn't mind the linked hydro pedals.
I'm surprised to discover that there are more tractors on the market with this feature and it can't be disengaged. This definitely slipped past me in all my research. This underscores the importance of always demoing a machine before committing to purchasing it.
But as far as your jerkiness complaint.....too bad they didn't do like some tractor brands and put a reactivity setting dial so you can control the reactiveness of the hydro.
The only way I could see them implementing that is through electronic linked HSTs like the Kubota HST+.
I'll have to see if my dealer has one yet and go try it just for the heck of it.
Doubt I'll want it though.
If you are interested in this model then I definitely encourage you to try it for yourself. And when you do let us know what your experience is with it.
/ Kubota LX4020 Already Having Problems #42
On my Branson 2610h I occasionally wish I could disengage the auto throttle. I usually run the brush cutter in the economy PTO mode and setting the hand throttle to 1850 rpms. In mid range the auto throttle won't allow full ground speed without also raising rpms above the 540 mark. In high range however the 1850 rpms isn't enough torque to mow up hill.
Same goes for cruising down the road. No reason to run 2700 rpms, but that's the only way to access maximum ground speed. My old Simplicity Sovereign garden tractor allowed 80-90% ground speed at any throttle setting.
Overall I'd still am glad I have auto throttle. The above are really just quirks and not significant complaints.
If you really want to, you can disconnect the cable at the injection pump. It's very easy and doesn't even need tools. Just a little rubber keeper out, disconnect the cable and put the rubber keeper back in.
Obviously not as practical as having a lever near the operator, but still doable if you want.
Well at least there is a possible work around.
/ Kubota LX4020 Already Having Problems #44
I might try it at some point to see how I like it.
/ Kubota LX4020 Already Having Problems #45
I have a LX4020, It's smooth, powerful, quiet, the loader is smooth as silk as well. The Auto Throttle is awesome as well. Just the title of this thread got me to click on it but I quickly found out it's total BS lol. "LX4020 Already Having Problems" Lol yeah if you count the guy that was out tire kicking
/ Kubota LX4020 Already Having Problems #46
I assure you sir, I know exactly how "auto throttle" works. I have been using my tractor with it (it came standard) for over 6 years now. This is such a non-event.
The LINKED PEDALS (instead of calling it "auto-throttle", if you prefer) was a feature to enhance front end loader work ease. No idea where you came up with the idea that it was only to be used for "transport across properties". I can only think Kubota finally included this due to being questioned so many times on why they don't offer it from so many new prospective customers. Most of their competition has already incorporated it in at least part of their lineup.
I think you're possibly operating under an incorrect mindset. The auto throttle does not "lock the transmission" into anything. The motion pedal (only forward on the Kubota, no idea why) has an additional mechanical linkage that actuates the throttle on the engine. It is a mechanical apparatus. It cannot be "switched" on and off. There is no computer involved in this function. It is built in when they assemble the tractor.
If you want to run anything off of the pto, you simply run up the hand throttle to your desired pto rpms and go. I do this frequently myself. There is zero drama. The motion pedals provide ground motion as before. You can pto operate yourself all around, over hills and over dales.
The pedals are "jerky" because you are ham-footing the pedals. If you raise the rpms with the hand throttle and then "ham-foot" the pedals, it will be jerky too. Even more so, because with raised rpms, your hydro pump will have more flow. You have to "learn" your foot pedal. No idea what tractor you're comparing it to, but you can't just jump in the cab and start stomping pedals in any hydro tractor I've been on. At least not if they have mechanical pedal linkages. Part of being a "pro-operator", instead of just a "seat dummy", is knowing your equipment, and how to operate it smoothly. That takes adapting to each piece of equipment differently.
Sounds like it's an operator issue as well as the salesman may not understand the feature.
Or more like a guy that hates Kubota for some reason.
/ Kubota LX4020 Already Having Problems #48
O:n my Yanmar YT235C I set the lever on the dash for 1700
rpm and then use the foot petal for what ever speed I want. I
also have the cruise control.
willy
/ Kubota LX4020 Already Having Problems #49
Yeah I sure hate Kubota that's why I took two days out of my busy schedule last week to go down there and try them out.
Well you need to blame yourself instead of Kubota for not knowing how to operate the tractor. A few posters that own that exact tractor have mentioned you were not operating it correctly.
How to operate
/ Kubota LX4020 Already Having Problems #50
Perhaps that salesman did not inform the customer how it
works?????? Not all salesman know what they are selling
and how they work or how to operate one. Just facts
willy
/ Kubota LX4020 Already Having Problems #51
willy
That is obviously true in this case. Sad really, (and kind of comical) that there were salesmen and service techs crawling all over the thing trying to figure out how to turn something off that cannot be "turned off".
/ Kubota LX4020 Already Having Problems #52
Sadly I've seen this for years spec'ing and ordering new class 8 trucks. Salesman that have NO clue how to spec a truck for a specific application, and not even any idea what is actually available from the factory.
Yet they still expect you to pay them a commission for writing up the order. Tell me where the logic is in that?
/ Kubota LX4020 Already Having Problems #54
I haven’t seen a salesman do a good job of explaining the Yanmar iHMT yet. Not too hard if you study up on it. It was scaled down from big ag tractors.
/ Kubota LX4020 Already Having Problems #55
Sometimes I mess with checkers in grocery stores. I buy rather obscure produce and they get confused. Lack of product knowledge is not limited to vehicle dealers.
/ Kubota LX4020 Already Having Problems #56
Its thread titles like this that should be changed by the original posters.
If thread title = not true, then it should be changed to reflect that.
Idea on more accurate title?
"Kubota LX4020 Already Having Problems? Not Now."
Just my opinion, YMMV!
/ Kubota LX4020 Already Having Problems #57
he's like the "You Tubers" gotta have click bait. LOL
/ Kubota LX4020 Already Having Problems #58
I went from geared tractors with foot gas pedals to HST+ with auto-throttle (no DPF or DEF) so the transition was easy and intuitive. Previously I would step on the gas pedal to go faster. Now I just step on the HST pedal. Great for loader work.
My M59 has a mechanical switch on the control panel and you can easily shut off auto-throttle.
If you have DPF, leaving the throttle on full at all times is probably a good idea. I don't have DPF/DEF. I don't always want to hear the engine roar so auto-throttle is welcome for me.
/ Kubota LX4020 Already Having Problems #59
SDLANCH SDLC1220 High-End Carport (A64194)
SDLANCH SDLC1220...
1999 22ft Sea Ray Boat w/ 2015 23ft Shorelander T/A Boat Trailer (A64557)
1999 22ft Sea Ray...
2025 24in Mini Excavator Bucket Attachment (A64553)
2025 24in Mini...
New/Unused 12V Diesel Pump with 50ft Hose (A65583)
New/Unused 12V...
(1) 20 Yard Roll Off Dumpster and (1) 40 Yard Roll Off Dumpster (A65579)
(1) 20 Yard Roll...
36in Backhoe Bucket (A65579)
36in Backhoe...
