Best seeder for bermuda grass- drop v broadcast, etc
/ Best seeder for bermuda grass- drop v broadcast, etc #1
xsf18cdf
Member
JD1025, Kubota L6060HSTC
Looking for ideas ref type of seeder, not about type of grass- already have type going to use. Bermuda is so fine and dust-like it seems the broadcast would not be as effective even mixing with sand or corn meal.
/ Best seeder for bermuda grass- drop v broadcast, etc #2
For this type seed, I use a drop spreader and mix the seed with dry lime, pelleted lime or fertilizer. Ken Sweet
/ Best seeder for bermuda grass- drop v broadcast, etc #3
Another cheap option that seed companies sell for spreading fine seed is rice hulls. Mix the seed with the rice hulls and it allows fine seed to spread with either seeder type. Most of the large grass seed distributors sell the rice hulls online for very cheap.
Aaah ok...just mix it in a fresh cement mixer? - I have one that I've used in the past for mixing other amendments and that's all its for.
That's for both of you....haha
The one on your site looks perfect. I'll check back in when I get back from this contract- I'm in Iraq right now.
/ Best seeder for bermuda grass- drop v broadcast, etc #6
Does no one in your area sprig grass ? Down here Coastal Bermuda is almost 100% sprigged.
Its not coastal Bermuda (Texas Tough+ Blend) and I'm trying to not pay anyone to do this because that puts me at the mercy of their schedule and usually the bigger jobs win out. This will be the second time its been seeded- the first time was beautiful but I was away on contract and my wife (city girl) left the critters to eat on the pasture all winter and destroyed it. I've got a pretty good system as far as timing goes. Its me doing it solo now though. The only question is will I be doing it with the Kubota or will I have the LS by then.
/ Best seeder for bermuda grass- drop v broadcast, etc #8
Can you share your system for overseeding an existing pasture? My 6 acres of horse pasture got overgrazed real bad last year and this year the drought has been awful. Right now, I have Beef Builder annual rye out, to help hold it all through the winter and give me something to disk in. Another rain and it should start popping.
In the spring, I'm planning to overseed with Buckaroo Blend Bermuda Grass. Currently, looking at tilling/seeding options and considering my strategy. I have a disk harrow, chain harrow and broadcast spreader and hoping to make do with that. But I'd rent an overseeder (If I can find one to rent) if that's going to give better results.
I am going to light/shallow disc (my pasture is straight sugar sand over 12ft deep) add some lime and nitrogen, seed, cultipack and then put a light straw mulch. Last time I has beautiful wispy grass that was nearly 3ft tall before I could get it cut. I contract overseas and am away often but I am retiring so I will be able to take care of it more appropriately.
Oh forgot...I use Texas Tough + which is a blend of cool and warm, drought resistance types of bermuda and could not be more pleased with it. I do apply it a lot heavier than the instructions say, but my soil is not the best.
/ Best seeder for bermuda grass- drop v broadcast, etc #10
How many acres are you doing and how are you putting out the straw mulch? Sounds like you have ideal soil for Bermuda with that deep sand. I'm on black clay which has its challenges for growing just about anything.
5.5ac and was going to try a manure spreader. I'm south of you in Weatherford.
/ Best seeder for bermuda grass- drop v broadcast, etc #12
I'm hoping to time it that I disk in the bermuda seed right as the rye starts to die back. Hopefully acts as a mulch of sort. I'll send out some soil samples later this winter and work on adding whatever amendments before planting time.
Good luck with your efforts. We'll have to share our results and see if we have anything we can add to the tribal knowledge for future efforts.
Yes, of course. Take care.
GH
/ Best seeder for bermuda grass- drop v broadcast, etc #14
I understand not wanting to be at other peoples mercy, I have never heard of this Texas Tough + Blend. Are you going to cut this for hay? Or just let animals graze it?
/ Best seeder for bermuda grass- drop v broadcast, etc #16
I'm not familiar with how fine Bermuda seed is but I use 2 different methods for sowing clover and alfalfa, and timothy seed. For the clover and alfalfa I use the Seed~Easy spreader to spread the seed, it just can't be too windy. For timothy seed I use the Toro 93 slit seeder for ground contact because it's usually sown in mid-Sept. It's only 4' wide, but instructions say it can be used up to 7 mph so you can scoot right along. It takes about 2-1/2 hrs. to do my 4 acre hayfield.
I gave $100 for the slit seeder at a school surplus auction. The had no use for it after installing astro-turf. Around here certain equipment dealers rent them for around $200 a day. Beats putting $6-7K in an implement you only use at more once a year. Both do a great job in their own right. Just some food for thought.
Thanks! This seed type is fine- not quite talcum but almost a powder.
Thanks for responding. I am going to see if I can find a used seeder in good working order when I get back in town.
G
/ Best seeder for bermuda grass- drop v broadcast, etc #18
You can probably also check places that rent equipment I'd rather spend a couple hundred dollars to see if it will even work than tie a good bit more up in a piece of equipment and not work as planned.
You might even try contacting your local Extension Office. Here they have a no till drill you can rent for like $15 an acre and they deliver to your door. Part of the taxes you pay are providing for that service whether you use it or not.
/ Best seeder for bermuda grass- drop v broadcast, etc #19
I'm going to look around and see if I can find a rental. I have a pretty good "in" with the local Kubota dealer. He might even know a customer that has one I can rent.
Great idea...hadn't even thought about that.
Thanks!
G
BOBCAT T190 (A60736)
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2025 Unused SDLGC80 Electric Golf Cart (A60352)
2025 Unused...
2015 MACK CXU613 DAY CAB (A59906)
2015 MACK CXU613...
2007 MACK CHN613 DAY CAB (A59906)
2007 MACK CHN613...
