Jimna 254 hard starting
/ Jimna 254 hard starting #1
Jimmy254
Jimna 254
My 2006 254 has been hard to start since i bought it a few months ago. It used to start after until accidently leaving the fuel tap off and running out of fuel. After repriming It then would not start at all and produced lots of white smoke which i believe may be unburnt fuel. The only way i got it to go was keep trying for a very long time or as i figured out eventually a jumper start. Once it started the white smoke cleared up. Ive since got rid of the fuel strainer and tap and fitted an external filter. Ive also replaced the glow plugs. It still wont start on this battery even though it reads 13.4volts between the starter positive and chassis and the little window on top of the battery is green. Its not a big issue as it is most likely a weak battery but i do find it strange as it caused me a fair bit of grief trying to figure it out and this may be of use to someone. Ill get the battery tested once i get around to it.
/ Jimna 254 hard starting #2
Good plan. You can test the battery yourself. Read the voltage while you are cranking it over. If below ~10v the battery is most likely getting weak.
Glow plugs can be tested with a multi-meter set to read ohms. I don't remember the resistance off the top of my head, but you can check against a new one for comparison. If you test them in the engine, you have to remove the bus bar at the top otherwise you test them all and not just the individual plugs.
Are you aware of the procedure to use the hand primer pump and the bleeder screws to get air out of the fuel system? Once the fuel system is purged that far, it will usually start after a bit of cranking. If not, you sometimes have to crack the hard line nuts at the injectors and crank some more to get the air out of the hard lines.
I did follow the hand primer and bleeding procedure. That wasnt the cause. I even cracked the hard nuts at the injectors to confirm a dribble of fuel at each injector. With the glow plugs i used the amp meter on the dash to isolate the faulty plugs. Cant remember exactly how but i disconnected each one in turn to see if the drawdown on the tractor meter is affected. With all 3 working they should draw towards 30 amps.
/ Jimna 254 hard starting #4
Good work on the glow plugs, you did it right.
As for the hard starting after getting air in the system. You did all the right things. I think sometimes things can just be cantankerous.
Sometimes cursing like a drunken sailor seems to help. Other times it just annoys those around you with no help at all to the issue at hand.
You can "flood" a diesel just like any other engine. If you suspect that, just hold the fuel cut off out and continue cranking until you don't see any smoke. Then start the procedure over. Cranking with the fuel in cutoff does help to pre-heat the combustion chamber. You basically have a 3 cylinder air compressor at that point. The heat of compression warms the head and aids in starting.It also get the oil circulating before startup, which is a good thing too.
Each engine has it's quirks and with experience you will get to know what it needs for every starting situation. I run my Jinma 284 from -30 F to 100+ F. Sometimes it is more difficult to start but once I learned how to heat it and how to set the fuel and selectively crank it, it has never failed to start. Well, there was one time at -30 when the starter would spin but not engage. Some heat on the starter fixed that and eventually it did start that day.
Very interesting info regarding your use of the fuel cutout. If you can start yours at that temp i shouldnt have an issue. That is really cold. Im not likely to have to start it below 32.
My dog slinks away when im working on machines because im always cursing if things go wrong.
/ Jimna 254 hard starting #6
My secret weapon for cold starts. 1000 Watt tank heater. Depending on the outside temp it will heat the head to summer temps in less than an hour.
/ Jimna 254 hard starting #7
White smoke=generally unburnt fuel. I'm thinking a bad 1 or more injectors. If they are dribbling. This would also give the hard starting symptoms. Easy and cheap to do.
Dave
Could be the injectors however the smoke clears up completely once it starts.
/ Jimna 254 hard starting #9
Where do you set the throttle when you start it?
Generally, I just nudge the hand throttle until the peddle moves about a quarter inch. A little more or less depending on air temp and if it is the first start of the day.
I havent settled on exact throttle starting position yet because i still can not get it to start consistently on the first start of the day and we are not talking cold weather either. Some days it goes first kick. Other days it doesnt and i have to walk away and try again later and this sometimes does the trick. I have replaced the battery and 2 glow plugs that were not working. Ive replaced the fuel line. Ill try the throttle position you suggested however surely it wouldnt be that sensitive given it has glow plugs. If there is a problem to my mind it has to be either not enough crank or maybe a compression leak but why does it start sometimes? Could it be a compression leak? There are no symptons of water in the oil or oil in water. Well nothing very obvious anyway. There is no moisture coming from the exhaust. No bubbles in the coolant. I have just put in a new water pump as the previous one was leaking. Ive checked thermostat opens at the right temp. The tractor does not run hot. It stays at 60deg on the meter and i after a bit of work in the morning i can comfortably touch the radiator and engine. Battery is new and i am careful to charge it after use if i think ive tried to many cranks. Where do i go from here. I havent torqued the head bolts. The toolbox that came with the tractor has a spare head gasket so suspect the one in the tractor hasnt been replaced but who knows. Engine runs perfectly once started. I have read a lot about retorquing the head bolts. Could that help?
I should add i have also done a compression test on the cooling system. No obvious leaks. A small amount of coolant does come out the radiator cap overflow but from what i have read that may be normal. So i dont suspect a leak into the coolant system.
/ Jimna 254 hard starting #13
How many hours on your machine?
Head bolt torque shouldn't effect starting unless they are so loose they leak.
Does your tractor have the decompression lever? If so, you need to check it is traveling properly. Also, you can use it to spin the engine up to speed and then "drop" it for sudden increase in compression. You can't start the engine with the decompression lever activated, but it will let the starter get it spinning faster, then use the inertial to your advantage. Works best in cold weather.
The throttle is your mixture control lever. Think of it as the choke on your lawn mower. There is no air control so all you have is fuel control. Too rich and it won't start. Not enough fuel and it won't start. Fortunately there is a pretty wide band of settings where it will start.
I've had mine for nearly 17 years and know all the tricks to get it started, yet it does not always fire off on the first attempt. Especially the first start of the day.
A few seconds of glow plug. The set throttle to be just barely cracked open. When it starts the setting should let it run at 1000 to 1200 rpm. Spin the starter for a few seconds and watch the smoke. If it doesn't catch in 5 to 10 seconds. Stop and hit the glow plugs for another 10 seconds while the starter cools off a little. Then hit it again. You can also try different throttle settings at this point until you find the one that works.
After it starts, the rpms will pick up a bit as it warms up, back that off until you are at ~1000 and in a few minutes it will be ready to work.
As for the thermostat, 60C is not warm enough. These little engines like to run in the 85 to 90C range. It made a huge difference in performance when I went to a hotter thermostat.
Ive got a theory that it could be the positive lead connector at the battery that is at fault. Cant work on it until 2 wks time but this would explain why it would always start with jumper leads. The jumper lead was connected to the cable not the connector or the battery post so it bypassed the positive connector that looks like a copper washer with a hole in it. I had noticed that connector appeared thin and worn.
Machine has 150hrs on it but its 17 years old. Yes it has a decompression lever. 60 deg does seem too low. Where did you find a hotter thermostat? The way you describe starting is pretty much my experience except for first starts.
/ Jimna 254 hard starting #16
This is a cross reference sheet that came with my tractor. The hand written notes are mine.
If I remember correctly the NAPA thermostat was a few thousands of an inch too large on the outer diameter to fit in the housing. I gently filed the edge all the way around until it fit properly. The one problem I had is the old bolts that go through the housing were in really bad condition. I think two of the four twisted off and I had to extract the left over bits. Never any fun. I put in all new ones with lots of anti-seize compound on them.
It certainly wouldn't hurt to go through the head bolt torque and valve adjustment procedures.
Some of these tractors were assembled with fully painted starters which acted as insulation. The only ground they were getting was through the mounting bolts and the little bit of metal the lock washers scraped back.
It never hurts to take every electrical connection apart and clean all the surfaces until shiny metal is exposed. Starting at both battery terminals and working outward. You would be surprised how much resistance can build up on a dirty connection.
If you have the time and desire, when you get to the starter, while you have the wires off, remove the starter. Do the same shiny metal stuff at both mounting bolts and under the bosses where it contacts the bell housing. The more surface contact you have the more amps can flow through it. Also, take the starter apart and have a look inside. Clean all the contacts in the solenoid and at the commutator. A little white lithium grease on the sliding/spinning bits will help a bunch. Don't forget the bushings at each end. You will be surprised at how much more power your starter will have. All just simple maintenance stuff, just a little time consuming.
Another thing to consider is internal cable corrosion. I have seen cables that look completely fine on the outside be so corroded on the inside that they would pass only a small amount of current. For an example: The positive battery cable gets moisture inside and corrodes. You test it with a multi-meter and get battery voltage at the far end. This is fine when there is no current flowing through it, but as soon as you put a load on the cable, it becomes a big resistor and all of a sudden you are only seeing 8 or 9 volts. The tendency is to think "oh, oh, the battery is bad". That happens but if your pretty sure it is not that case, use a set of jumpers to bypass the vehicle cables.
  • PartsX-ref.pdf
Some great info there. Cleaning takes time but not as much time as buying and fitting parts that dont fix the problem. That chart wil come in very handy, thank you. How old is your tractor? You said you have had it for 17 years. Was it new. So far all the bolts ive undone have been in very good condition which i am surprised by given its had many years outdoors (not near the ocean though). My thermostat housing bolts were like new. The only trouble i had was trying to fit a new fuel filter tap and bowl into the tank but the new filter thread was bad quality.
/ Jimna 254 hard starting #18
My 284 was made in October of 2006. I got it in Jan of 2007. Tractor, backhoe and front end loader all in the factory crates. Put it together in my shop. Plowed snow with it that winter, then used it to install a new septic system the next summer. It's not perfect (people sneer and look down at their noses at me because it doesn't have hydro-drive or a cab) but it is simple to work on, and fairly durable if you don't abuse it. Price was right too.
Old chinese proverb which I made up myself just now. 'People who sneer down at cheap tractor owe lots of money'
I alternate between thinking this is a bargain and this is a lemon at least twice a day. I think it will be fine though. It's almost there. To think that a faulty fuse blade can bring a couple of tonnes of machinery to a standstill and take more than a day to fix it isn't surprising that things sometimes just need a bit of attention. I'll be using mine for clearing a bit of light scrub and forest litter, firewood, track maintenance with the box blade, landscaping etc etc. Backhow should be handy too. I hope to find a bit of clay i can use for repairing a dam. Backhoe is off at the moment, it has a fairly decent hydraulic fluid leak in a spot where I can not figure out how to get too. Its is probably just a loose fitting.
Can you please point me in the right direction for the valve adjustment procedure and the head torque specs.
/ Jimna 254 hard starting #20
Head re-torque starts on page 34 of the first document on this page:
The second document on the web page has lots of good info and drawings in it too. I don't see the specs for the valves. I will have to do some digging on that.
