Good morning!!!!
   / Good morning!!!! #178,511
The overnight lows wont be as low as last night and the highs are going into the 40-50° range for the rest of the week. This is a good thing. I still have three heavy duty tarps to put on the three shelters. I didn't have the money then, now I do and also the time to put them up. I don't do manual labour in the heat.
It pains me that I have a 1 year old $9,300.oo lawn mower sitting outside in the elements. When I went back to work, the roofs were cracked on two of the shelters and the tractor shelter was already tarped.
As long as the wind stays down, they WILL get done this week.
   / Good morning!!!! #178,512
Wind WSW 17 gusting to 25 mph. Light rain/snow. we might get the inch they are talking about,
Morning all!
39 this morning going to 59. Very nice!
Just got back in after a two hour walk about with the back pack blower. Then, I unleashed the beast for another two hours. Even though it mulches as it scoops I still filled it to the brim 3 times!
beast:
from this:
to this:
Time to head to the wood shop for some relaxation.
Hope everyone stays safe and healthy!
Phil...do you use leaves for mulch or do leaves rot away before next year?
   / Good morning!!!! #178,514
well I got it done.
I think.
chopped off all the ends of the rv toilet hoses and started over.
had to go back downtown to get some plumbing cement and more clamps.
letting it dry overnight before I turn water pump on.
Twice I did that, once got water in face, second fitting came totally apart and flooded floor. Sigh.
well just clean water and I had plenty of towels ready.
it needs to go to Popgadgets and made to look professional with pex fittings.
What I have now is marginal and sure to come apart in at the worst time.
I also need to install that master cutoff as Ron suggested.
nice day out, blue sky and clouds
   / Good morning!!!! #178,515
54F and cloudy @ 14:30, calling for a high of 55F. Low here this morning was 37.8F.
Got started going through paperwork yesterday related to household information. I've never gone through all of it and organized it ... it's a total dog's breakfast ... :(
Multiple folders for the same thing, and many misfilings ... like the installation instructions for the whole house vacuum in a folder labelled "Water" ... :rolleyes:
This was all prompted by an issue that raised it's ugly head a week or so ago.
The slight trickle leak coming out of the water softener increased significantly ... to the point that I shut the softener off and put it on bypass.
Was initially looking at just going ahead and replacing the softener but rather than just throwing $$$ at the problem I figured I'd dig into it a little deeper.
Took a water sample down to our local water treatment place to have it tested and it showed hardness as 9 gpg, pH 7.0, .5 ppm iron, and TDS of 327.
Talked to a tech down there about the softener issue after explaining the situation and got a "Oh you don't want to spend $2K on a softener ... I can rebuild that valve ..."
So I told him I wasn't planning one spending $2K on a softener ... since I can get a Fleck (pre-filled with resin) off Amazon for around $700 - $800.
But to explore things I asked "Ok, so what's involved in rebuilding it ?" ... meaning what are we looking at as far as the cost goes.
He ballparked it at around $300 but wanted to come out and look at it so we set up a service call for him to come take a look.
He came out this past Thursday (an hour early), took a look, and checked the softener to see if it was operating. Price had gone up to more like $500 ... rather than $300 he talked about earlier.
And his tone had changed from a supremely confident "I can rebuild those don't waste the money on a new softener" to "Weeeell, you can take a chance and roll the dice and sink the money in it ... or just buy a new one ... which we can install for you."
For $2400 - $2500 ... and if we bought the softener from them, they wouldn't charge us for the $95 service call to come out and look at it.
Told him I'd have to discuss it with The Woman and let him know.
A couple of things about this kind of rub me the wrong way:
1. The change in tone between the conversation at their shop and after he got here.
2. Difference in price between the shop and here - for both repairing the softener and replacing it.
3. When he came early for the appointment last Thursday, he sat in his truck in front of the house for probably 15 - 20 minutes yakking on the phone to someone ... with me sitting out there in a lawn chair.
The final factor is that this is the same company that came out when we were having problems with the well being low-producing in 2012 and the company owner, who came out, diagnosed it as the pump being bad.
They replaced the pump at that time ... and within 24 hours we were having the same problem. I still have the old pump ... which I insisted on keeping when they replaced it.
End result of that (after some discussion) was they cut their bill in half, said we basically got the pump at their cost.
So, having initially inquired (online) about rebuilding this valve back in 2020, I've been watching YouTube's on how to do it. It ain't rocket science.
New piston is $85.
New injector screen is $4.
New seal and spacer set is $34.
The Stuffer Tool to install the spacers and seals is $98 ... but it can be rented (for 30 days) for half that. It isn't necessarily required and I found a trick on the videos I watch to use a substitute (rolled piece of stiff paper or thin plastic)
Brine valve appears to be seized currently ... if that can't be restored maybe another $100 for that.
So since the softener is out of service at the moment anyways, I'm going to disconnect it and tear into it and see what I can see.
I did manage to locate the original receipt for the softener, was installed back in 1993 and is a Fleck 2500 or 2510 Econominder (metered) with the brass valve body (newer ones are plastic or resin), 32,000 grain and was loaded with fine mesh resin.
Still have not located the original bill for the drilling of well and the drilling report. Had my hands on it at one point, no telling where it is now ... :rolleyes:
Also located what I assume are most of the receipts for the submersible well pumps that were installed.
As part of eliminating the too regular replacement of submersible pumps I'm going to be ordering a Cycle Sensor and a Cycle Stop Valve from TBN member Valveman ... which should reduce pump cycling, prevent rapid cycling, and prevent the pump running dry for extended periods.
Hope everyone is having a decent Monday ... (y)
   / Good morning!!!! #178,517
Sounds like a very reasoned approach RS. Save money.
   / Good morning!!!! #178,518
Here is a picture of a tractor model that I worked on many years ago during my apprentice years. It is a two stroke single cylinder diesel engine started by hand by rotating the flywheel. Lots of low end torque
   / Good morning!!!! #178,520
Tire shop called early saying the camper tires were in. So I took the tires in to tire shop 2 at a time in the subaru. I used a couple spare tires I bought once for my other trailer, to hold the camper temporary while I had each pair changed. They were quick, took the young man about 10 minutes to get the first 2 done, I said I'd be back later. Went home, and looked like the Dukes of Hazzard changing those tires around, course more like Jesse Duke. Went back with the other pair, and another quick turn around. I tipped him. I have never tipped a guy changing my tires before, but he was so quick. If I had taken the 2 china bombs to costco to change, it would have been hours waiting for each pair.
camper is now sitting on 4 new Goodyear tires, and the china bombs were returned to costco. I know the Girl in the costco tire shop, she used to play baseball in Rec league with my oldest son many years ago. And the girl at the costco gas pump gave me a big hug in front of everyone, also a longtime friend... Even found my wife who happened to be in Costco the same time I took the tires back, so I hunted her down using the FindMy app on my phone, and helped her shop. Glad to have that job done. These were original tires on the camper almost 12 years old. tread looked like new, but cracking on the sides.
The new 20 ton bottle jack i bought from amazon last week was a real help. And the new gravel parking pad made it nice.
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57453)
New/Unused AGT...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2011 NORAM POWER...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
2015 Ford F-250 Reading Service Truck (A56858)
2015 Ford F-250...
2006 CATERPILLAR 320CL EXCAVATOR (A59823)
2006 CATERPILLAR...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
