Good morning!!!!
   / Good morning!!!! #178,301
I read they fixed the overheating by throttling it somehow, not sure they fixed anything.
got the rv couch screwed in and everything put back. Looks good.
not so successful in bathroom. It's going to take some basic plumbing to
get into this hose since no adapters were available. I do wonder if that whole thing was taken apart
and reconfigured whether it might work. I can't get my head in there, just stuck a camera out
one thing is for sure, fitting on Dometic 320 toilet not the same as household.
Check with marine supply places, they usually sell Dometic.
   / Good morning!!!! #178,302
Got the camper pad about done. Wife wants it away from shed enough to open awning, so will probably add a couple feet in width, and might go back 3 ft more. There is about 2 ft now from tires to edge, but gravel slopes down some, and don’t want to have to try to back it in right on the blind edge. I did not use my laser level at all putting in the pad, so went out a few minutes ago to put the laser on it. It is dead on level.
Now it will settle some, but couldn’t believe how level I got it. A good drop at the back so left a pile of dirt to slope it down. Will pull the old gate out one of these days.
   / Good morning!!!! #178,303
The gray piece looks like a threaded PVC pipe nipple, and I would hazard a guess that the black hex fitting would be pipe thread.
   / Good morning!!!! #178,305
You got good eye doing such work,maybe we should call you Dirt Doctor. ;)
   / Good morning!!!! #178,306
63F clear sky.
Busy day at work and leg stiff up last couple hours. 🙄
Boy O boy the leaves fell today :eek: couple hours of blowing leaves able to put dent in them,tomorrw afternoon try get couple more areas somewhat clean up for heavy rain arrive early AM Saturday all day.
Plans for the evening share bowl ice cream watch some YT.
Enjoy your evening all.
   / Good morning!!!! #178,307
It was all luck. wish I had a track loader to dig with, where you can see the front of the bucket. Washing my windows on the cab would help me see better also.. I finally got around to putting the lock and lube on the grease gun. really nice, but had one zerk I could not get, so had to switch it again to get that one on bottom of the hoe pivot.
We are doing our saturday breakfast tomorrow with the gang, so not sure it I'll get any more work done or not. Maybe can work on widening the pad a bit. Still got a bunch of old osb siding from the shed that needs burned, might have a camp fire tomorrow...
also, I mentioned to wife about replacing our blue spruce with a dogwood tree, and she is OK with it.
   / Good morning!!!! #178,308
Don and Kyle, you may be getting both of these total solar eclipses? ...Mostly and LS maybe one?
Don't know where you live, two-bit.
Yes, it will be crossing directly over us (Annular eclipse). Already planning on getting all the welding masks ready!
   / Good morning!!!! #178,309
Good (Friday) morning. Overnight Low of 2.4C and it's presently 15.8C, clear with the odd breeze.
Doing a 'turn' around Wagtail Park (mostly looking for any more wind/tree damage) I noticed that the 'Mad Horse Woman' was having the saddle fitting done. Other than that, all's well around the property.
I'm ready to start setting up & manning at the Polling Centre tomorrow morning (and throughout the week). I get there at a "sparrow's f@rt" (Aussie for 'very early') so I'm in for loooong days. Weather long-cast for next week looks good.
Because of this I'll be reporting in rather sporadically.
   / Good morning!!!! #178,310
No progress, just wasted time this morning. My network reconfiguration required moving a Ubiquiti component from Cottage to house. Was hoping just relocating to opposite end wouldn’t require major reconfiguration. Wrong, unit wouldn’t even power up. Tried everything I could think and every suggestion I could Google. Apparently it has just died. Out of warranty of course. Gave up and ordered replacement. Grrrrr
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
METRIC DUAL CUT TAP & DIE SET (A58374)
METRIC DUAL CUT...
2017 VOLVO VNL64T TANDEM AXLE SLEEPER TRUCK (A58018)
2017 VOLVO VNL64T...
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
2014 Ford E-450 Super Duty Shuttle Bus (A56858)
2014 Ford E-450...
2022 Horizon Trailer (A55973)
2022 Horizon...
