What have you done to your Branson today?
   / What have you done to your Branson today? #1,511
I put a tree puller on it!! It did well, I am sure my technique (I have only pulled 3 trees so far) is the only thing holding this thing back.
Looking forward to having more time to pull up some trees!!
   / What have you done to your Branson today? #1,512
Ok, now pull the same plate on the other side of the driveshaft with 4 bolts. This will expose the coupling on the transmission side.
If the leaks happens to be the seal #6 or the o-ring #5, it's still an easy fix with the worst part being having to drain the transmission oil. Branson made it so you can just pull the drive shaft out, and the pop out a sleeve the has the seal #6 and o-ring #5 without having to split the tractor.
Yes, I opened it before writing, and I saw the seal holder, but I'm not sure this is the problem because as much as I can see everything in the bell housing is covered with oil. The dealer going to bring his mechanic with a camera. I hope it is this #5&#6.
   / What have you done to your Branson today? #1,513
I installed a 12k lb winch. I got a universal fit mounting tray and cut it to fit, had to modify the front brush guard a bit, add a few brackets, and also had to switch the fairlead out to a low profile version so the loader arm could clear, but it now fits perfectly with no issues. I already used it to move a few felled trees and it did great!
   / What have you done to your Branson today? #1,514
Do you take the power from the tractor battery or you installed additional somewhere?
   / What have you done to your Branson today? #1,515
I'm using the tractor battery / alternator and it seems to work just fine.
   / What have you done to your Branson today? #1,516
OK, I see. Asked because I thought about it for the tractor and my utv, and while making research most ppl recommend an additional battery installed in parallel.
looks sharp BTW.
   / What have you done to your Branson today? #1,517
looks sharp BTW.
I would think that would depend on how frequently you use the winch, and for how long. If it is just used occasionally, the one battery will work fine. If you plan on using it regularly for hauling trees up hills with chokers, maybe two batteries may not even be enough.
   / What have you done to your Branson today? #1,518
And the alternator is only 50A if I remember correctly. At least on the ROPS models.
   / What have you done to your Branson today? #1,519
I assume you got the 12k because the cost at HF is so reasonable - or did you think "I actually need 12k pulling power"? I've contemplated putting a winch on mine but I don't know that I need the full 12k...
   / What have you done to your Branson today? #1,520
is the tree pulling more a matter of loader lift or tilting the "bucket" / grabber back?
Case 950 8 Row Air Planter (A56436)
Case 950 8 Row Air...
2018 Ram 5500 4x4 Crew Cab Utility Flatbed Truck (A55973)
2018 Ram 5500 4x4...
2006 JCB 520 Telehandler (A59213)
2006 JCB 520...
2016 SERCO 8500 KNUCKLEBOOM LOADER (A58018)
2016 SERCO 8500...
1980 PULLMAN DRYVAN (A58214)
1980 PULLMAN...
2017 Ford F-550 Crew Cab Enclosed Service Truck w/ Liftgate (A56858)
2017 Ford F-550...
