Restarting My '70 Nova Project
   / Restarting My '70 Nova Project
Well, we finally got some rain. I think it rained continually
for almost two hours this afternoon. Went out a little bit ago,
and I was amazed the rain gauge had 2.3 inches in it!
I had the shop doors open when it started raining, but after
a while the wind came up and I had to close them as it was
blowing several feet into the shop.
I finished masking off the front of the car and gave it a couple
of coats of the undercoating. Pulled the paper and tape, and
after it dried it looks really good. That stuff is expensive,
but looks really good when it dries.
I put the things I took off to do the masking and spraying back
on the car, so that's another job done!
I decided to get the screws/pins that hold the rear window
trim on, so I made a little piece of angle iron with a hole in it
to use as a gauge to drill the holes in the right position. I had to put
six screws on the passenger side and four on the driver's
side. I did some experimenting and a 5/64" bit was the best
size for the screws. They're pretty small, #4 screws with a
flat head and a shoulder that stops them at the correct height
for the clips to slide on to.
There are several clips for the trim at the bottom of the
windshield, and the new cowl piece that was installed has
no holes, so I'm not sure, but I think I'll have to get the
windshield installed so I know where they go. There
are also two additional stops that hold the bottom of the windshield
in the right position, so those will have to be figured out
too. I guess it's about time to get the glass put in it.
It's been a pretty busy week, and considering making a few trips for parts amd paint, waiting for parts to be delivered and other miscellaneous supplies, I got a fair amount of work done on the Nova.
I got the headlights assembled after I got a pair of new retainer rings, as the old ones weren't even the correct ones and they were covered with overspray and and other filth. I also replaced the headlight buckets as almost all, 4 out of 6, holes for the retainer screws were stripped out and larger sheet metals screws installed. It looked like crap. After that, I dug out the grille supports that bolt to the radiator support. I had bought a new pair, but upon examination, the old ones were in pretty good shape, the left one was slightly bent, but straightened out okay. I bead blasted them and gave them a coat of paint and they look like brand new.
I pulled the grille down for the forest of other hanging parts and looked it over really closely. Other than a few really minor dings, overspray and flaking paint, it would clean up just fine. I cleaned up all the crud on it, and masked off the top and bottom horizontal bars that are bare metal, and scuffed up the rest of the black painted areas. I smoothed out a few areas so it looked pretty good, blew it off and wiped it down with naptha. Gave it a couple of coats of satin black, let it dry and pulled the tape off. Not too bad.
There is a plastic filler plate that fastens to the bottom of the grille and fills the space down to the bumper, and it needed some attention. It had a piece broken out of it on the front side and a couple of other cracks that needed repair. Some JB Weld glued the broken piece back in place, and I forced some of it into the cracks by flexing them open and smearing it into the area. I managed to get it through the cracks and out the other side, so it made a good repair for those spots. After the JB Weld set up, I block sanded the repairs smooth and scuffed up the rest of the piece, and it didn't look too bad. It is supposed to be painted Argent Silver, the same color used on steel rally wheels on GM and a couple of other makes, but no one in the area had any of that on hand. Eastwood only had a 2-part spray can, but at $30 for the paint and another $20 shipping, I decided to substitute a can of metallic silver used on Toyotas, or so the can says, instead. Actually, I think it looks pretty good, a nice bright metallic silver, way better than it looked before.
Yesterday I called a local fellow that does glass work on classic cars, and had him order the windshield and rear window. He said depending on whether they are available locally or not it might be a week or little more until he can get out to install them. That will be a big step in the project. After that I'll need to get the vinyl top on and then get the trim on the sail panel and the windshield and rear wind trim installed.
Today, I pulled the rear springs out and got them cleaned up and gave them a good coat of frame paint. Judging by the number stamped on them, they are the original springs. Both have the same amount of arch, so they are good to reinstall. First though, I had to press the front bushings out and install the aluminum bushings for the Cal-Trac traction bars that I have for it. I was able to lay the springs on a plank on top of a rolling work cart and get them to just the right height to get into the press. I used a 30mm 1/2" drive impact socket and a couple of spacers to press the old bushings out and the new aluminum bushing in. It only took about 15 minutes to do both of them, and another 20 minutes to clean up the mess from the Never-Seize that I used when I pressed in the new bushings, per Calvert's instructions.
I installed the rocker units that attach to the front of the springs, then
pulled the mounts that the front of the springs attach to, cleaned them up and gave them a coat of undercoating. After that was dry I bolted the right side mount back on the car and maneuvered the spring into it, and got the pivot bolt installed. I got the new shackle bushings installed in the rear of the spring and the frame, but they are too wide, and the shackle bolts aren't long enough to get the nuts on them. Hmmmm. The old bushings are about 1/4" narrower on each side, but I can only find four of the eight, I may have tossed the rest of the olds ones when I took it apart.
The bolts have a square area under the heads, like a carriage bolt, but it sticks out enough that it hits the bushing before the shackle plate is up against the bushing, and that takes up almost 1/4". I think that if I chuck them in the lathe and machine the extra squared area off, and I'm able to get a clamp of some sort into the close quarters where they sit, I might be able to get the nuts started and tightened up. If that isn't enough, I may try machining a little material off the bushings themselves. They are pretty hard urethane, so that might work. If I get that sorted out, I may pull the differential down off the rack and get it ready to put under the car and get it off the rotisserie.
Stay tuned.
   / Restarting My '70 Nova Project #363
Sounds like your great project is coming along nicely. Nothing seems to slow you down, and being capable and having the machinery and skill to be mainly self reliant is a big plus as well. I really enjoy your updates and pictures. Getting closer and closer to getting it done. Keep up the great work.
Thanks.
Yes, having to right tools for the job makes a big difference when you run into a problem or procedure that requires special tools. After collecting tools for almost 60 years, there aren't too many I need on a regular basis that I don't have. If I need something more than a couple of times, I buy it or make one like it if possible. I bought that hydraulic press in 1983, and has been required to do repairs more times than I can remember, especially when I had some trucks on the road.
About the only tool I still covet is a mill. I almost bought one that was in an estate sale of an old friend, but although it was a Bridgeport, it was in pretty bad shape. I'm looking at a Precision Mathews mill, maybe after the Nova expenditures taper off.
I really looking forward to be able to drive the car, especially after going to the season finale cruise-in at a local Amish restaurant, Das Dutchman Essenhaus. They have the cruise-ins every Thursday from May through the end of September, and the last one of the season always draws a huge crowd. Last Thursday it was estimated at around 1500 cars, I saw everything from a 1904 Oldsmobile to a brand new McLaren, with a huge number of 60s and 70s muscle cars. A forty acre area was filled with cars and people.
Well, time to head down to the shop and figure out the shackle bushing problem.
After my niece's husband and I left the cruise-in, we hit the buffet. Oh crap, I ate too much, probably set my diet back a week. Kinda pricey though, right at $20 for an adult, but lots of really good food.
   / Restarting My '70 Nova Project #367
Haven't eaten there in quite a while. Last time was a large group and we had the family style. :p
So, back to the original topic.
I machined the shackle bolts to allow them to slide all the way into the bushings, then chucked each of the shackle bushings in the lathe and reduced their shoulder thickness by about 1/8", maybe 3/16". The urethane actually cut pretty sell, as it's pretty stiff stuff. After those modifications, the shackles went together with no problems. I didn't tighten them all the way down, as that needs to be done once the rear suspension has it's normal weight on it and they are in the static position. I dug out the cherry picker and retrieved the differential from the top of my metal/wood storage rack. Sat it on a couple of jack stands, dusted it off and looked it over really well, nothing obvious after setting up there for 10 years. I turned it 180° and removed the chrome cover, drained the lube and looked it over. Just for giggles, I set up a dial indicator to make sure I had set the backlash correctly when I replaced the open carrier with an Eaton posi unit soon after I bought it. It was right on at .010", so it's good to go.
With my floor jack and some fancy maneuvering and lowering the body about a foot, I got the differential in place on the springs. Pulled out the old u-bolts and the bottom plates for the Cal-Tracs and when I tried to assemble them, two of the u-bolts were too short. I have no idea why two are longer than the other two, but there must have been a reason. But that was 10 years ago and I've slept since then.
So, off I went to the local Power Brake and Spring store to get a couple of longer (7/16" x 7") u-bolts. They didn't have any in 7/16" stock, but did have that size in 1/2" stock. I went ahead an bought four of those and the nuts, and was pleasantly surprised as it only came to $30.
Took them back to thew shop and cleaned them up and gave all the pieces a coat of black paint.
Today, I got the u-bolts installed and torqued down, them installed the adjuster tubes for the Cal-Tracs and torqued the rod end bolts up to spec.
Ater that, I pulled out the rear shocks, cleaned them up and got them installed. That all went pretty well, just had to jack up the axle a couple of inches to get the bottom ends of the shocks on their studs and the washers and nuts installed.
Earlier, I realized I hadn't refilled the diff, I didn't have but a pint of 80W-90 Limited Slip gear lube, so I made a trip into O'Reilly's and picked up three quarts of Castrol lube. Got the diff filled up, cleaned up the spillage, and decided to go ahead and hook up the brake line. That was a little tricky as the hose from the diff to the hard line is almost too short, but I got it together and tightened up.
When I had pulled the diff out of the car, cleaned it u and painted it, I decided to change the driveshaft from the original 1310 series u-joints to the beefier 1350 series. I had bought a new yoke for the pinion and had a devil of a time getting it on as it fit really tight. I even called the vendor, Strange Mfg., they had me make a couple of measurements and said it was the proper one and to try heating it a little when installing it, not so hot as to damage the pinion seal, just pretty hot to the touch. That helped it a lot and was able to pull it on the last 1/4" or so with the nut. So, then I needed a 1350 yoke for the transmission, and I knew I had bought one when I had bought the Tremec TKO transmission several years ago. After searching for a while, I thought I must have left it on that transmission when I sold it, but I really didn't think I did.
So, this evening, after supper, I went back down to the shop, did some more searhing, and lo and behold, I found it in a small storage bin on a shelf of a work cart. In with it was the pivot ball that the clutch throw out lever pivots on, which screws into the bellhousing, that I had been searching for also.
Two mysteries solved this evening. (y)
It looks like next on the agenda it to get the engine off the engine stand, on to a different stand so I can install the bellhousing and check the concentricity of the crankshaft and the pilot hole for the front bearing housing of the transmission. Tremec cautions that more than .005" of misalignment can cause input shaft bearing failure, and I don't want that. The Muncie transmissions are a little more forgiving, so the concentricity isn't as critical.
So, progress was made this week, and hopefully that will continue.
   / Restarting My '70 Nova Project #372
Looking great. Making great headway now. I really enjoy your very detailed and concise updates.
I cann,t remember, did you re-build the engine yourself ? What HP and Torque numbers does it have ?
I rebuilt the original 350, as it was drinking oil quite profusely. I have the receipts from the previous owner showing it was rebuilt by a NAPA shop a couple of years and a couple of thousand miles before I bought it. But when I tore it down, the ring gaps were not spaced correctly and had very little tension, they almost fell out of the bores once the rods were unbolted. I'm thinking that it was overheated and that's what killed the ring tension. That engine is preserved in a plastic bag in my shop, as is the original Muncie transmission, which I also completely rebuilt.
The engine I am going to install in it now is a small block 434 stroker motor, built from a 4 bolt main truck block with an Eagle 4 inch stroke rotating assembly, Eagle I-beam rods and Mahle pistons. I bought a set of aluminum heads with 2.02" intakes, 1.60" exhaust valves and 64cc chambers, so it should have a static compression ratio of 10.5 to 1. For a cam, I used a Comp Cams Nostalgia 30-30 hydraulic flat tappet unit, which is a copy of the old 327 350hp cam. To fuel it, I have an MSD Atomic electronic fuel injection unit and for exhaust a set of Magna-Flow headers. I am, I think, going to replace the headers with a set from Doug's Headers as the Magna-Flows have only 1 5/8" tubes and a couple of the plugs are really hard to get out and tend to scorch the plug wires.
I wanted to install a transmission with an overdrive, so I ended up with a Tremec TKX unit with a .68:1 5th gear, which will give me 1900rpm at 60mph, instead of the 3000rpm with the Muncie transmission.
Here is what the cylinders looked like when I pulled them off the 350.
Here is the 434 I built up.
   / Restarting My '70 Nova Project #374
Awesome. Thanks for all the great info and the pictures. Looking forward to a video of your new engine running once it has been installed in your beautiful car, and at least one video of a smokey burn-out. LOL .
Here you go.
This was when I had set the engine and trans up in the subframe so I could test fit it with the body.
I have a better video, but Imgur only allows 60 second videos, and it's 1:07 long.:(
Edit: BTW, since that video was shot a year ago in March, I've lost over 40lbs.
   / Restarting My '70 Nova Project #376
Awesome, sounds great. That has got to be a great feeling to fire it up and hear it run. Love the sound of the lumpy cam.
   / Restarting My '70 Nova Project #377
Who do you have your beautiful Nova insured with ? Do you have an agreed to value on it ? I have 3 cars insured with Hagerty, all of them with a mutually agreed to value, just in case something bad goes wrong with any of them.
I have them on my Cincinnati policy with my other car, truck and motorcycle. I have an agreed value that I can change when the restoration is finished.
I was thinking about checking out Hagerty once it's finished up.
Been doing a few things on the car, got the bumper filler and it's support assembled to the radiator support. ran a tach signal wire from the MSD ignition for the MSD EFI, I had forgotten about it when I was doing all the other wiring on the firewall.
I also pulled all the plugs and cleaned them, as when I had it running on the subframe, the O² sensor was in the collector adapter with no pipe or muffler attached and that made it think it was running lean and ran it really rich, and they were really sooted up. Interestingly, Engine Masters just aired an episode about positioning O² sensors that showed that very thing.
I also repositioned some wiring on the engine, installed the oil pressure and water temp sending units for the gauges, removed the motor mounts and installed a pair of supports for when I take the engine off the stand to dial indicate the flywheel and transmission bearing support bore.
After my friend Van and I came back from breakfast this morning, we hung the doors back on the body. With new door seals, they didn't want to close all the way at first, but I went back down this evening and they had compressed enough that I could get them closed all the way. I decided to install the springs that go in the lower door hinges to hold the door in position when it's open and I knew they were not going to be easy, and I was right. The driver's side wasn't too bad, it popped out of the compressor tool in the wrong place on one end, but I was able to get it pried into place. The passenger side wasn't so easy, I tried several times and finally the spring popped out of the tool and shot off to somewhere in the back of the shop. I searched for a while, but with all the stuff back there it could be in some little cranny and I'll never find it for years. I'll probably order a new one, or two, and this time tie a piece of wire or stout string on it so it can't get away if it pops out of the tool.
With the doors on the car, tomorrow I'll get the engine off the engine stand and on some blocks so I can check the crank concentricity. If that's good, I'll pull the flywheel and get it surfaced. It's gotten pretty rusty in the last 10 years, and I want a good surface for the clutch to mate with.
Been pecking away at the items at the top of my to-do list on the car, and making some progress.
I got the engine off the engine stand and on to some 6X6 blocks on the floor, as I don't have an available table that I would trust to support the weight of the engine and transmission once it's installed. First job was to get the bellhousing checked for axial runout as the Tremec installation instructions state that there shouldn't more than .005" of runout. I bolted the new bellhousing to the engine and managed to get one of my dial indicators attached to a 7/16" X 3" bolt that replaced one of the flywheel bolts. It was a fiddly setup at best, but it gave me the bad news that the transmission opening was way out of spec. The readings started at .000" at the 6 o'clock position, -.006" at 3 o'clock, -.032" at 12 o'clock and -.022" at 9 o'clock. Not good. :(
After some calculations I figured a pair of .021" offset bellhousing dowels would be needed to get it into the correct position. I got a couple from Summit Racing, and after fiddling (not the f word I wanted to use) with those for several hours, I couldn't get it close enough to work. I pulled the new bellhousing off and installed the old one from the 350, and bingo, it was almost perfect with about .004" TIR! But, when it checked the fit on the front bearing housing on the Tremec, it fit like a saddle on a sow, probably .020"-.030" of clearance in the bellhousing bore. So, back to square one. Last evening I ordered a couple of other offset dowels, hoping some combination of them would get it into spec.
Later on, I began thinking about the possibility that the combination of one of the original dowels and one of the offset dowels might do the job. I wondered about that because when the new bellhousing was installed with the original dowels, it was apparent that the dowel holes in it were not spaced properly, as you couldn't get it to seat against the block without a little tapping with a fist or mallet. With that in mind, This afternoon I picked the resurfaced flywheel form the shop and bolted it on the engine. Then I reinstalled an original dowel in the left side and one of the offset dowels in the right side. I rotated the offset dowel until the housing slipped on with very little effort. I also ditched my original dial indicator setup and used my Noga magnetic articulated dial indicator mount that uses a 1" travel indicator, and that worked a lot better. I set the crank so the indicator was at the 6 o'clock position, zeroed it, and rotated it around to the other three positions, and OMG, it was within .004". I double checked it and it came out at between .003" and .004" total runout. JUST TO BE SURE, I pulled the bellhousing off and reinstalled it and indicated it again and came up with .003" TIR. Bingo!
I pulled the housing off, reinstalled a flywheel bolt I had to remove to get the magnetic base to set level and rechecked the torque on all the bolts. By then my friend Brian had stopped over, and he wanted to watch and learn, and help to get the transmission installed. I showed him how the clutch is installed with the pilot tool and evenly torqued up. Then I installed the throwout fork in the bellhousing and mounted it back on the engine. We carried the transmission over and sat it on my floor jack to help with sliding it into place, and once properly aligned, it slid in all the way except for about 3/4". That's when the input shaft goes into the pilot bearing. After some jiggling and shoving wasn't working, I got a big long pry bar and was able to have Brian use it to pry the throwout fork enough to release the clutch, and it slipped in the rest of the way. I bolted it in and we discussed just how that worked, as he's not very experienced with the mechanical workings of cars.
That done, it was 6PM and we called it a day.
Progress!
   / Restarting My '70 Nova Project #380
Great write-up. I ,m very impressed with all the mechanical knowledge you have, and continue to display. I like seeing that you are so committed to getting everything right. Awesome build. I would have zero issues about buying one of your completed projects. Cheers
2014 Ford F-250 Ext. Cab Service Truck (A59230)
2014 Ford F-250...
CASE ROOT PLOW (A58214)
CASE ROOT PLOW...
2022 Brush Wolf 4800X Severe - Duty Excavator / Backhoe Brush Cutter (A57024)
2022 Brush Wolf...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 Bobcat T770 Compact Track Loader (A56438)
2017 Bobcat T770...
2019 FREIGHTLINER WATER TRUCK (A58214)
2019 FREIGHTLINER...
