Good morning!!!!
   / Good morning!!!! #177,571
Drew is it safe for you to stay?
be careful
yes, thank you
much less safe to leave
no where to go, this storm is coming up the coast, no where to run
it's a tropical storm, not a hurricane, and rvs get dicey at 75mph.
this will not gust over 50. If power stays on, Verizon has four bars here so my internet works and I have lots of food.
I'm in the middle of basically a concrete parking lot in the lee of the dunes.
my only thought might be to bring in the slide, but it's a really small slide with a small slide topper. It's the topper I don't want to blow away but I checked it and it seemed fine. I am checking around the floor near the slide and no leaks, those rubber seals are doing their job.
I had thought about staying in Washington, but I'd be under pine trees and the system is going right over that area. So nothing to be gained.
this is fine, what I expected. Next time I'll bring a face mask...actually a set of swimming googles would be good, though I wound up with sand stuck to beard stubble
this wind blowing in off the ocean is creating real problems for inlets, bays and rivers, blowing the water upstream and flooding will likely be widespread. My friend in DE said Milton was already putting down sand bags.
   / Good morning!!!! #177,572
67°F and .13 inches rain.
Very good day mowing yesterday. Drive, Laupahoehoe end of property done. If wx cooperates hopefully the Hilo end can get done today.
Pool temp chilled a bit to 78°. Getting hints that fixing the heater should become a higher priority.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #177,573
No crops left to be harvested in my area of VA Drew....too dry for too long.
Stay safe....50mph is of concern for winds.
Gee Scott....your a few steps ahead of me. Bad timing on my part closing pool. With the wet weather coming I imagine lots of cleanup before closing. Bad on me....scheduling.
   / Good morning!!!! #177,574
wind and rain picked up even more, looks like worst of it now through tonight. I pulled in the slide and it helped reduce the rocking a little.
but now wind has picked up even more and the jiggling continues
two large fifth wheel trailers came in together right near me. Those poor folks who had to set up for at least half an hour outside in this downpour.
I'm catching up on a good book and taking an occasional nap to the sound of rain pounding on the roof. Pretty nice actually.
   / Good morning!!!! #177,575
We got set up along the river. We at least 40 ft above the river, so no flood danger. Just over the hill from where we almost bought land.
Train tracks across river is the train we are riding next month. It went thru right after we pulled in, so I didn’t actually see it but it was whistling for a crossing.
Nice breeze today. Too bad weather will get wet
Cows across the river, some in the river.
My mobley internet works, cell tower in sight up on the hill above the river.
   / Good morning!!!! #177,576
Good Afternoon Guys,
Mike, I am guessing your pool water temperature is not down to 72 like mine was this morning, but I can certainly understand your concern over the storm thats coming through. I finally got all the lines blown out, plugs installed on all inlets and outlets and finally got the cover on. I did that by myself, which every year I say this is the last year I can do this, but always manage to do it one more year ! :ROFLMAO:
Drew, some nice beach pics, sorry you had to get sand blasted to take them !
BEF, also some nice pics, looks like your weather is a bit better than Drew's !
Everyone enjoy your afternoon !
   / Good morning!!!! #177,578
Perhaps break it into two contracts and let the plummer do piping stuff only
Could be a good approach. Find someone to do the concrete busting, rough digging as prep for plumber. It could be that a concrete guy could just cut and remove enough concrete to make it easier for the plumber?
Thinking about my dilemma a few years back having to replace gas line under the driveway. Solution ended up being renting a concrete saw to cut a narrow path, remove, then dig down. It was work, but proved the better approach. I just bricked in the trench where I suspect you would permanently repair.
2008 FORD F350 SUPERDUTY XL UTILITY TRUCK (A58214)
2008 FORD F350...
2013 Sakai SV510 Pad Roller, Chassis# VSV21-1033, PMC Power Motive, Cummins Turbo Diesel Engine, (A59076)
2013 Sakai SV510...
2025 Ligchine Spiderscreed Concrete Screed (A56857)
2025 Ligchine...
16 T/A TRASH TRAILER (A58216)
16 T/A TRASH...
2016 Kubota MX5200 (A57148)
2016 Kubota MX5200...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
