Drill baby drill!(Directionally, HDD content)
   / Drill baby drill!(Directionally, HDD content)
Broken shaft that wallered out the pulley when it stopped spinning. New kit with updated larger shaft, pulley, spacers and bearing 2468.09.
Ouch, that hurts.
The downtime is worse than the $, but at least they could still get it for me the machine is pretty old.
   / Drill baby drill!(Directionally, HDD content) #14
Sure send me a PM.
   / Drill baby drill!(Directionally, HDD content) #15
So could this work to install a pipe in an existing pond dam ?
   / Drill baby drill!(Directionally, HDD content) #16
Those machines fascinate me, not the actual machine per se but how you can aim it in elevation and lateral direction. Any chance you can give an explanation? I remember seeing a pic where one went off course and ended up going thru a car in a parking lot across the street.
Here's a great clip showing how they work:
   / Drill baby drill!(Directionally, HDD content) #17
Awesome video, should have thought to check his channel, he does some great videos.
   / Drill baby drill!(Directionally, HDD content) #18
I consider a drill like this to be based on magic, and operator skill.
   / Drill baby drill!(Directionally, HDD content) #19
Ditchwitch JT 10, with manual load rods?
Edit: NVM, saw you said 10 ft rods, so more like an older version of the JT20? Or is this a Toro machine? Driller I know picked up a Toro demo unit for pretty cheap, think $170,000 for a 2024, with only a dozen or so hours. Same machine from Veermer is pushing, what, $400k, with tanks, trailer, ect.
Overflow pipe? I don't think it'd be right for that.
Bigger but older. Jt1720, auto rod loader, 10ft rods, 17k lbs of thrust vs 10k on the jt10. If I like this type if work(vs plowing and missiling) I'll use this one to make the $ to buy a newer better one if this unit has too many problems.
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
2017 Nissan Murano SUV (A50324)
2017 Nissan Murano...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
Kuhn SR108 Speed Rake (A50515)
Kuhn SR108 Speed...
John Deere 693 Corn Head (A50514)
John Deere 693...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
