Just arrived and hour meter is broken
/ Just arrived and hour meter is broken #1
Atypical_decorum
NYC
Ultra-Wide B7500 & looking for a 100hp
Well, I got my M105s a few hours ago. Been playing with it and besides a loose steering wheel and worn FL tire it looks good. I glanced down at the hours and guess what. It hasn't moved!!
This thing could have 10k hours on it! I bought it from a kubota dealership out of state who explicity told me via voice, email, and ad that is had 1555hrs. Well, 2 hours later it still does.
Whats my recourse? He's not answering his cell phone at the moment.
/ Just arrived and hour meter is broken #4
Does the tach work? What rpm were you running the new tractor at?
The tach is broken. You can see the 1/10 hour mark bouncing as the gear tries to catch, but it just jumps a tiny bit but won't roll over.
You can't do anything, so don't bother. He can say it broke in transit, and it may have.
For $30,000 fraudulent practice, that's not small claims court. What's your reasoning?
/ Just arrived and hour meter is broken #7
if your dealer is not responding, then contact central K & log your contacts
is tach electric or mechanical? prob electric. maybe remove positive battery terminal & reboot? good luck
It's mechanical. Dealer is in Mississippi.
/ Just arrived and hour meter is broken #9
I thought there was a law that protects you against that? I know in Canada here is some law about how you can't tamper with the hours or mileage.
Theres lemon laws and false advertising laws the consumer affairs dept handles. They have the the power of court behind them. I'm going to see what the place says Monday, then start talking to the agencies/lawyer in their area. $30k is not a small sum to be duped out of.
/ Just arrived and hour meter is broken #11
Buyer beware is about the only law in most states for used agricultural equipment. Sounds like he, The seller tampered with the hour meter which broke it to register the hours he told you.
Most state take the position it is your responsibility as the buyer of used agricultural equipment to insure what you are buying is what the seller says it is.
/ Just arrived and hour meter is broken #13
I will advise to fix the meter and continue with your life, and enjoy your tractor.
/ Just arrived and hour meter is broken #14
How does your meter operate?
Is it based on PTO speed? (engine has to run at certain speed to count hours)
Is it based on time when engine is just idling?
from 2004
  • Good Post
Reactions: D&D
/ Just arrived and hour meter is broken #15
The tractor was advertised as a 1500 hour tractor. It was bought as a 1500 hour tractor. And a 1500 hour tractor should be what he got.
It was the dealer that advertised it as such.
They should stand behind that.
Not sure why you are so ready to tell the buyer to get let it go unchallenged? Perhaps because it's not your money invested?
/ Just arrived and hour meter is broken #17
In todays world when it comes to used agricultural equipment it is, let the buyer beware. Such sales are usually, as is no warranty sales.
/ Just arrived and hour meter is broken #18
We don’t know if the dealer advertised the tractor had 1500 or what ever hours. The dealer probably said the hour meter on the tractor shows 1500 hours.
/ Just arrived and hour meter is broken #19
Mississippi? I'm almost positive you don't have much recourse. Maybe can get him to fork back a bit, but unless things have changed in past few years, no lemon law applies to a tractor. Only on road vehicles
/ Just arrived and hour meter is broken #20
From what I see they were made 2005 to 2007. For $30,000 I would have wanted to look it over first carefully. Maybe talk with a lawyer if you know one, probably not much you can do at this point.
I saw an ad for a Bobcat skid steer on Craigslist at a good price. Looking at it in person they had used it moving pallets of salt so lots of corrosion and couldn't find service records. Oil was black, dirty filters.
I moved on...
If the Kubota runs well otherwise and hour meter DID work...would you be happy?
There's a "cooling off rule": "As explained by the Federal Trade Commission (FTC), the federal cooling-off rules gives the consumer three days to cancel certain sales for a full refund."
Only you can decide what's best for you.
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
2019 DITCH WITCH TOWABLE VACUUM TRAILER (A63276)
2019 DITCH WITCH...
3pt Heavy Duty Carry-All, 3'x6' Platform (A62679)
3pt Heavy Duty...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
HYDRO TEK PRESSURE WASHER (A65643)
HYDRO TEK PRESSURE...
NEW 2025 Mini Skid Steer Stand On Loader (A62679)
NEW 2025 Mini Skid...
