Remember the thread on No Brakes again? (This is your brain on LS)
   / Remember the thread on No Brakes again? (This is your brain on LS)
I'm trying to get things documented. LS (factory) has said there are no records of the past repairs, yet I have a few e-mails to the former dealer where we discussed the hydraulic failure and other issues. Apparently the former dealer made no effort to keep records.
Here's what LS had to say: RECEIVED FINAL RESPONSE FROM BUSINESS : LS reply to further allegations made by (name deleted)
I have received another complaint form from the BBB involving more unsubstantiated claims of problems. There are also allegations against a former dealers claiming poor record keeping. Much of this contains opinions, accusations and name calling.
The facts are : (1) There is no record of most of the claims made by (Name deleted).
(2)The current dealer indicated he tightened some fasteners on the joystick control. As mentioned earlier, the operator's manual advises to check daily for loose bolts, ETC.
(3) It has been stated earlier that there was some welding done because of damage from loose fasteners.
(4) Not only the current dealer, but also an LS service manager has inspected his tractor before returning the tractor to (name deleted) and both confirm there were no faults found at that time.
(5) As mentioned earlier, the brakes and related linkages were replaced as a safety measure even though no defect could be found at the dealership. The brakes have now been returned to LS for inspection. There is no fault in the brakes.
(6) LS Tractor has continued to support the dealer as the dealer has made efforts to address this customers fears and concerns, even though there have been no defective parts found.
In my opinion: There seems to be an effort on the part of (name deleted) to create other issues to further his claim of defects in the tractor. His tractor was inspected by our service manager and his dealer before being returned to (Name deleted). (Name deleted) alleges the instruments didn't operate when the tractor was returned. It is easy to unplug connectors to cause components to cease operation. It is easy to loosen fittings to cause a leak so it is reasonable to suspect this may be caused by the customer in the effort to make a list of issues.
There also seems to be an effort on the part of (Name deleted) to repeatedly contact the service manager and ask redundant questions. I am not sure why but I suspect he is simply attempting to be bothersome. The dealer indicates he has always answered to questions (Name Deleted) has had.
(Name Deleted)
Head of Service
LS Tractor USA
(Name Deleted) refers either to myself or to the representative of LS.
Now then, here's part of what the new dealer had to say:
Hydraulic leak was repaired before I bought the dealership, no warranty was filed, this leads me to believe that it was only a loose fitting. No power issues were found by the the previous dealer, the solution was to train the owner on proper use of the tractor, he was a very inexperienced operator for the functions that he was trying to use, no repairs were required, only training. Joystick was never broken, two bolts were tightened to correct this issue. The backhoe was welded twice as a courtesy to the owner. The owner's manual requires scheduled checks of all mounting hardware for the backhoe. The welds are not required but the dealer that sold him the tractor added the 1st weld as a courtesy. I noticed while I was at the tractor owners house, doing a free oil change for him, that the weld could have been a little cleaner and had it welded again at no charge to the customer, again as a courtesy.
The current dealer told me that a pin on the joystick had broken and it had to be replaced. (Word of mouth). Now the story changes to it being a loose nut or bolt. What am I supposed to believe?
So, LS isn't telling the whole story. I do have a good amount of documentation that clearly supports my side. This weekend I intend to get the local Sheriff's Dept out to my place and show them what has happened - especially in light that I've been accused wrongly by LS for vandalizing my own tractor.
BTW, do any LS owners - particularly of the LS XR series tractors have your original warranty information available? I started to look for mine, and I can't seem to find it. All I remember getting was the completed loan application forms the day of delivery. I'm wondering if a slick one was pulled on me then too.
George, LS doesn't want to do my warranty repairs. I've been given all kinds of hints that "You're too finicky with your tractor. You should be satisfied with it just like it is." Who in their right mind would buy a car and not want it right from the dealer? To me, there is no difference there and with my tractor. I paid for a new, unblemished tractor, and I didn't receive one. Therefore I want a full refund. Oh, and George, if you want my LS hats, I'm more than willing to give them to you. They've never been worn, just placed on bookshelf.
I had e-mailed the dealer and LS representatives. I told them about the dashboard and other things not working. They then went into their rant about me being too fussy. I was very deliberate in the questions I asked them, and they eventually stopped answering my e-mails. That's service for you.
Attorney has been contacted. Something about consumer protection laws come into effect. I will need to finish getting my documentation together and send to them. For one, I need to find my warranty agreement.
   / Remember the thread on No Brakes again? (This is your brain on LS) #12
I'd take the 2 covers off under the dash and look for a harness that came unplugged or start checking for any bad fuses for the dash gauges. I suspect the harness is unplugged since your video shows you can start it. Very easy to remove them.
That's already been done. No loose cables, etc were able to be seen.
   / Remember the thread on No Brakes again? (This is your brain on LS) #14
did they fix the parking brake?
I don't know for sure yet. As soon as I noticed the non-functioning dashboard, I decided to park the tractor to avoid any further damage.
   / Remember the thread on No Brakes again? (This is your brain on LS) #17
I'm sorry to hear you're having troubles with your LS.
One thing that caught my attention was the mention of welding being done on the backhoe. Was the welding done prior to your tractor's last trip to the dealer, or while it was at the dealer? Is it possible the battery was not disconnected when the welding was done?
The welding was done by the original dealer to help stabilize the backhoe. It was done without my permission before the tractor was delivered. He said he'd had problems with the bolts coming loose, and they decided to weld the frame to prevent the movement. I do not know how to weld, and I don't own any stick or those other fancy welders. I leave that stuff up to the pros.
I have no idea if the battery was disconnected or not. I cannot answer that question as I wasn't there at the time.
However, this dashboard malfunction happened during/after the last repair. I know it was working because I wrote down the meter reading before it left my place.
   / Remember the thread on No Brakes again? (This is your brain on LS) #19
I guess I'm not clear if the last welding repair was done with the rest of the repairs, but if it was and the battery wasn't disconnected that could explain some of the issues. I'm not a mechanic but it seems like there's either a loose connection someplace or a problem with an electronic component.
Would you mind PM'ing me some details and who you talked to at LS? I'd like to try and help out if I can.
The original welding was done when the tractor was brand new and then delivered to me. I had no knowledge the first dealer was going to do this. He just showed up with my tractor and dropped it off.
4 Unused Montreal ST205/75R15 Trailer Tires (A55787)
4 Unused Montreal...
2021 Caterpillar 272D3XE Compact Wheel Loader Skid Steer (A55973)
2021 Caterpillar...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
10 ft Shipping Container (A55973)
10 ft Shipping...
DEUTZ MARATHON...
PICKUP TOOLBOX (A58214)
PICKUP TOOLBOX...
