Has anyone put a quick disconnect on a grease gun?
/ Has anyone put a quick disconnect on a grease gun? #1
crazyal
Super Member
Northern Vermont
Kubota, Case, Deere
I have a luck n lube connector for my grease gun but rarely use it because there's a few spots where it can't fit on my tractor. Not wanting to switch back and forth it's sat mostly unused. I actually forgot I had it. I now have a second hose for my Milwaukee cordless grease gun so I was thinking that I could put a hydraulic disconnect on the grease gun so I could switch back and forth easily.
/ Has anyone put a quick disconnect on a grease gun? #2
Just buy another grease gun, it doesn't hurt to have two, or three, or four. Between the garage and shop I must have 5 or 6 grease guns laying around. It's handy when you run one out of grease, just grab another.
/ Has anyone put a quick disconnect on a grease gun? #3
Yep^
I keep two just because I always seem to run out of grease in the middle of a job. Second one has a standard fitting so it reaches all the spots the lock’n’lube doesn’t.
I use a Milwaukee cordless grease gun. I have no plans to get a second one because I like the plastic case that comes with the kit. Every other grease gun I have owned has always found dirt and grime while leaving grease on things it never touched. With the case that doesn't happen. But it takes up a lot of room on the shelf. So one is enough. This week I'll find a 1/8" NPT quick disconnect and see how well it works.
/ Has anyone put a quick disconnect on a grease gun? #6
Just screw a grease fitting on the back of the spare hose and clip it on the lock&lube.
/ Has anyone put a quick disconnect on a grease gun? #7
Like the last two ideas. They do make 10,000psi hydraulic quick disconnects. Much more expensive.
/ Has anyone put a quick disconnect on a grease gun? #8
Would one of these solve your problem?
90 Degree Adapter
I've found it to help me to reach every tight zerk fitting I've encountered.
Good luck.
/ Has anyone put a quick disconnect on a grease gun? #9
Jjt I do to. And all mine are manual no battery. Some small ones. I tell my wife I like a variety
/ Has anyone put a quick disconnect on a grease gun? #10
I’ve got probably 5 manual guns. I’ve never used any of them since I got my battery gun a few years ago.
/ Has anyone put a quick disconnect on a grease gun? #11
Same.
Lock N Lube makes it easy to disconnect.
/ Has anyone put a quick disconnect on a grease gun? #12
I use a couple ideas expressed above. I prefer a tube rather than a hose so I can apply pressure to those worn zerks and I have a right angle adapter on it.
gg
/ Has anyone put a quick disconnect on a grease gun? #13
Grease guns get up to 3500 lbs of pressure. I had a D7 Cat and a grease gun is how you tighten the tracks. Just keep two wrenches handy and change hose ends.
ALWAYS wear gloves. I've seen more than one fella in the hospital trying to save an arm because grease was shot under his skin on a finger. Them battery guns get treated like Fisher Price toys, but they ain't no toy.
/ Has anyone put a quick disconnect on a grease gun? #14
It’s more like 10,000 psi.
/ Has anyone put a quick disconnect on a grease gun? #15
Man, I won't sleep for two days knowing that. But I did mean the hand pumpers. I don't have any battery anything except flashlight and vehicle.
/ Has anyone put a quick disconnect on a grease gun? #16
Well I’ve had that notion several times. I’m 68 years old. They say only a fool never changes his mind. Well, my mind changes rapidly. Go to the coffee shop and someone say they put out to much grease. Any way I just don’t think I need one. It’s to easy and infrequent. Just be a new toy
/ Has anyone put a quick disconnect on a grease gun? #17
A pump gun isn’t that bad for hitting a few zerks on a tractor loader. I was laying under my semi trailer today greasing the brake slack adjusters thinking how much worse the job would suck with a pump gun. If I’m greasing my mini x and skid steer together that’s a couple tube job and that’s no fun with a pump gun either.
/ Has anyone put a quick disconnect on a grease gun? #18
Lock a lube well worth the expense. Especially if you have a hard to reach spots that you need to grease regularly.
Clip it on and then get into a more comfortable position to pump the grease.
Had a new guy at work complaining about greasing the pivot points on semi trailer air brakes.
I passed him my pneumatic grease gun with the lock and lube.
He then realized why I said it was no big deal and I didn't mind climbing under the trailer to grease them
/ Has anyone put a quick disconnect on a grease gun? #19
I bought a barrel mounted pneumatic greaser on marketplace. It’s nice but it only came with like 10ft of hose. I need to swap that out to get much use from.
/ Has anyone put a quick disconnect on a grease gun? #20
I just have the pneumatic that accepts standard grease cartridges.
2020 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2020 GENIE...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58216)
2011 MULTIQUIP...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
2017 Toyota Camry Hybrid Sedan (A59231)
2017 Toyota Camry...
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
2018 Chevrolet Impala Sedan (A59231)
2018 Chevrolet...
