TODAYS SEAT TIME
/ TODAYS SEAT TIME #13,321
I forgot to take pictures of the yard work but it picked up enough debris to complete fill my dump trailer.
/ TODAYS SEAT TIME #13,322
To level an area you could use a water hose.
willy
/ TODAYS SEAT TIME #13,326
Its been raining here the last two days so no go but
its outside gettings its bath
willy
/ TODAYS SEAT TIME #13,328
Over the weekend I started extending one of my tractor roads. It was wetter than I like, but it won't get any dryer this time of year. The first part was pretty easy. I cut in there a couple years ago and backed the tractor in so it was wide enough. Just kind of rough and I dressed it up.
This is the next section. I have wheeler/snowshoe trail down thru there.
Which I widened out. It slabs down a side hill and is steeper than it looks.
Then I brought in my 1991 70 hp TD7G. It's a small dozer for the woods. The blade is 7'- 6" at the cutting edge and the tracks are 5'- 6" outside. Weighs 14,500 lbs.
I put my camera out and made a video cutting this section. I'm not a dozer operator - more like a kid in his sand box.
I made a little sweep at the top so I could pull a hitch thru the turn easier.
and this is at the bottom looking back up towards the turn.
The goal is to cut some wood down here while continuing the road. The ladder is my camera quad-pod :)
Some of you might enjoy this ( 19 minutes ) - I could see right off that I need more seat time. If you look at the last minute or so you can see how steep it is.
gg
/ TODAYS SEAT TIME #13,330
Rainning here again so no go
willy
/ TODAYS SEAT TIME #13,332
Your pictures are always easy on the eyes. Beautiful! The P/U seems to know there is something back there.
gg
conservatively the hay alone is 24,000 pounds, trailer is 7,000 pounds. Yep, the truck groans a little. Luckily I was only moving the hay from the field to the barn.
/ TODAYS SEAT TIME #13,334
I came home from a rotary cutting job, and the next day I noticed one tire getting low. SO, off I went to get my "self propelled" hydraulic trailer jack,
SO, with the spare now on the trailer, all is well.
SR
So you DO own a tractor made in this century!!!! (y)
/ TODAYS SEAT TIME #13,338
I spread 200 tons of fill on a barn pad. It still needs a few loads to get to grade.
/ TODAYS SEAT TIME #13,339
I spent about 2 hours hauling dirt to; fill in the hole I was going to
put a swimming pool in few more trips will be done
willy
Kubota RTV X1140 (A60462)
Kubota RTV X1140...
CAT D5G LGP DOZER (A58214)
CAT D5G LGP DOZER...
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2005 Chevrolet Impala Sedan (A56859)
2005 Chevrolet...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A58214)
2018 PJ TRAILER...
