M105S wide n low
/ M105S wide n low #1
Atypical_decorum
NYC
Ultra-Wide B7500 & looking for a 100hp
Hey guys. Got an M105s coming and I would like to change the tires out. 13.6x24 in front and 18.3x34 in back. I can keep the wheels, but am willing to get new or used.
My goal is to get as wide and low as I can without bottoming out.
I have 250ft clay hills that are at nearly 40 degrees I need to work on.
/ M105S wide n low #2
R1 Radials is what you need. Expensive sure but offer traction like no other.
/ M105S wide n low
It's currently got bias bar tires all around. But the rears are only 18" wide and 13ish wide in the front.
What size are you thinking?
/ M105S wide n low #4
I'm thinking: Front: 360/70R24 | Rear: 480/70R34
Won't get much lower but should get wider. Or may be contact some tire places and see what they can offer that's lower and wider. New rims will most likely be needed regardless of the tire size.
Another important detail is that engines have a limit to how much angle they can work. Unfortunately this not usually listed on the specs for the tractors. But some are in the 25 degree for up to 30 minutes or 35 degrees up to 1 minute. This is just an example of a Lombardini engine I found. Don't know about Kubota.
Not to long ago, a dealer here setup two M5111 pretty much as low riders for an almond farm.
2022 FORD F-150 (A63569)
2022 FORD F-150...
2014 JOHN DEERE 648H SKIDDER (A62129)
2014 JOHN DEERE...
John Deere 2155 (A62177)
John Deere 2155...
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
CAT 2 3PT HITCH BRACKET (A63745)
CAT 2 3PT HITCH...
Arrow Quip Head Holder (A64047)
Arrow Quip Head...
