Kubota engine rebuild problem
/ Kubota engine rebuild problem #1
jimd333
Newtown, ct
cub cadet 1641
The engine is a two cylinder diesel (Z500).
It's forty years old and has been rebuilt before.
I recently changed the piston rings. On startup, the engine lit off and immediately seized. I was told by Kubota that the connecting rod cap bolts are YTT ( yield to torque) bolts and shouldn't be reused as these were used at least two times before.
I removed the end caps and found no metal or damage, and while the crankshaft now turns, I believe the number 1 piston is hitting the cylinder head.
I was hoping not to have to remove the cylinder head again. Has anyone experienced a "spun bearing " before?
/ Kubota engine rebuild problem #2
Removed end caps or rod caps? If it was rod caps, you'd see the bearing problem right then. Are the Pistons turned the right way? Are the rod caps? I mark everything before I take it down. Are the rod caps on the rod they came off of?
Yes, rod caps is what I meant. It's too late to mark now, but I was working with a flashlight last evening. The number stamps on rod caps looked to be properly oriented with the rod.
What should I look for next? Should the bearing be replaced? Can I get this done without removing the cylinder head? Thank you.
/ Kubota engine rebuild problem #4
Is the piston hitting the head or a valve? Is there an foreign object smashed between the head and piston?
/ Kubota engine rebuild problem #5
Yep, they don't stop on their own.
I have the same engine in my Kenbota. It started life as a G3200 lawnmower with 1300+ hours. It's still running strong. The only thing I did was clean it, paint it and changed to a "real" alternator. It's no longer a lawnmower. ;)
Yes, the valve is being struck. I have very limited time to work on this, but will check in soon. Of course, everything is out of sequence! Thanks.
/ Kubota engine rebuild problem #7
Timing marks lined up? New valve springs? Pushrods/rockers in same places? Pistons in the same orientation? Lash set? What changed other than the rings?
2018 CATERPILLAR 320GC EXCAVATOR (A65053)
2018 CATERPILLAR...
JOHN DEERE 7200R TRACTOR (A64278)
JOHN DEERE 7200R...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2001 FREIGHTLINER FLD120 6X4 T/A DAY CAB TRUCK TRACTOR (A67147)
2001 FREIGHTLINER...
