Towing Safely
/ Towing Safely #1
yooperdave
Marinette, WI
Tool Cat 5600, LS XJ2025H, Branson 4215HC
I am moving 60 miles away. Part of the move includes me with my truck and trailers to haul most of the smaller stuff. The trip is pretty flat with well-paved roads everywhere. Intending to use all back roads and no highway travel while loaded.
I have a 2015 Chevy 2500 HD which I bought new with the 6.0 liter V8 with 35,000 miles on it. Works as intended.
I have a 7' x 12' single axle steel trailer bought new intended to tow my side x side.
I also have a double axle car hauler x 20' trailer I bought new. I added 18" high side rails so I could stack more items and have more places to tie-off.
Question: I carefully loaded the entire bed of the truck with steel racks and shelves. No real air spaces.
The weight could be north of 1,200#. The truck does not appear to be squatting very much so far.
Given this amount of load, can I still tow a fully loaded trailer? Leaning towards hooking up the smaller trailer to make the first trip.
The small trailer has around 1,000# in it. The large trailer has around 5,000# on it.
Is there a safe load chart to provide some assistance on what is considered a safe load when the truck bed is also loaded?
TIA
Yooper Dave
/ Towing Safely #3
If your small trailers have so little weight on it I'd be tempted to move some more weight to the trailers just for a more comfortable ride. But yeah, doesn't sound like a problem as you sound like you are well below GVWR for a 2500.
/ Towing Safely #4
Trailering capacities, at least on 1/2 ton trucks, are nearly always based on 10x tongue weight. This is because the typical rule of thumb is that your minimum tongue weight needs to be at least 10% GTW to prevent trailer sway at high speed. I haven't verified, but would assume the same probably carries over to 3/4 ton pickups.
For a conservative estimate, you could simply subtract the weight of the payload in the bed from your max tongue weight, and multiply the difference x10 for available tow rating. For a more aggressive estimate, you could take difference of GVWR and total payload (passengers + fuel + racks in bed), then multiply x10 for available tow rating. Somewhere between these two estimates is your effective available tow rating, I would think.
/ Towing Safely #5
Your manual will list the GCVWR... That is the total weight of the loaded truck plus loaded trailer.
Easy way to check is to go to a truck stop and get a weight on a truck scale.
GCVWR= Gross Combined Vehicle Weight Rating.
/ Towing Safely #6
I always wonder how we're supposed to get to the closest truck scale, sometimes quite a distance from home, without creating a violation the way there (and back?).
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
2020 International LT625 Sleeper 48" (A62613)
2020 International...
Kubota MX5400 land mgmt package
Kubota MX5400 land...
2017 Western Star 4700 Tri Axle Dump (A62613)
2017 Western Star...
2016 Autocar Xpeditor T/A Side Loader Garbage Truck (A61573)
2016 Autocar...
Adams 16T Tender Body (A63688)
Adams 16T Tender...
