Hydrolic fluid level
/ Hydrolic fluid level #1
ericbx1500
Gold Member
Michigan
BX2380, scotts 48
What is best practice when checking fluid level on bx. FEL cylinders retracted and bucket flat on ground and 3pt down?
/ Hydrolic fluid level #3
You could measure the level with all the cylinders extended and then with everything retracted to see how much difference shows up in the level.
Let us know, I would be curious, but not enough to go check on my own BX.
Doug in SW IA
/ Hydrolic fluid level #4
I always have checked fluid with all cylinders retracted. On a BX it probably doesn’t matter but move to a large TLB and you can see the difference. Fully extend those big cylinders then fill to the full mark and when you retract the cylinders watch how fluid runs out the top of the reservoir. :ROFLMAO: Don’t ask how I know.
/ Hydrolic fluid level #5
if i recall correctly, my industrial shows front bucket fully dumped and on ground. stabilizers down and hoe turned fully to side.
/ Hydrolic fluid level #6
i too have blown oil out the filler tube...oops
/ Hydrolic fluid level #7
It does make a difference. Check fluids and top up fluid with loader on the ground and 3 pt down.
If you then lift the loader to max height and check the fluid, it will show low. Do not add or will be overfilled once the loader comes down.
/ Hydrolic fluid level #8
I pulled that gem on my forklift once. Man, never saw a geyser shoot so high through the vent orifice. 🤣🤣
/ Hydrolic fluid level #9
I don't know if this is specific to Terramite backhoes, but their owner's manual says to put the bucket and outriggers down, but to raise the boom and digging bucket.
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
Tandem Axle Rear Truck Frame (A59228)
Tandem Axle Rear...
More info coming soon! (A56858)
More info coming...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2022 YANMAR VIO35-6A EXCAVATOR (A59823)
2022 YANMAR...
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
