CK2610
/ CK2610 #1
12Bravo
Gold Member
Eastern TN
Kioti CK2610 TLB, Gill 5' Scraper Blade (Tilt/Angle)
Anyone had an error code of 007 on a CK2610?
Just turn tractor off and now it's acting all kinds of funny. Electrical dash lights want to work then not work. The ignition switch is kind of sloppy, would this cause an error code 007?
Thanks in advance
/ CK2610 #2
I don't think that tractor can throw codes since it used a mechanically injected engine and therefore no ECM to throw codes. Are you sure it's not just the hour meter acting up?
/ CK2610
How would I test that?
When I turn the key, the electrical kind of goes nuts. It cranked once but wouldn't start. Where the hour meter is, all the way to the left "007" appears.
I'm not sure where to start since I don't have an ECM or codes.
/ CK2610 #4
Probably not related, buy I had tachometer totally weird out on mine with around 120 hours. I did not look at any other dashboard indications during this event. It was running and I looked at tach as I was running a brush hog, and it was pegged off the numbers on the high side of 4000 RPM. I turned it off and started it, and it dropped to 3600. I think another 'start and stop' and it was back to normal and problem hasn't reappeared.
You mention sloppy key (do you have a lot of keys on the ring?) and don't say if stored outside. Spray some contact cleaner in there and operate a few times as Item 2 below notes that it could be your problem. I guess I would do as many have mentioned on this forum and make sure your battery ground attachment is clean without paint under the landing spot. Mine was poor from the factory in this regard. I doubt it matters, but disconnecting the battery for a few seconds could make sure you're somewhat at baseline, but wouldn't affect a truly stuck relay/solenoid.
The factory service manual for checking hour meter operation is
1. Check fuse- 5 amp
2. Ignition Switch: 'Check proper connection with it in the "ON" positions: A-B-D' The image shows disconnection of the key switch at its first connector and checking those pins for continuity.
3. Check the regulator for operating power.
Also, a few more descriptive terms in the title when you post might get more responses. Good luck. For what it's worth, Toukow
2012 Allmand Bros. Maxi-Lite SHO-HD Light Tower 20KW (A63689)
2012 Allmand Bros...
Gravity Flow Wagon (A64127)
Gravity Flow Wagon...
2020 VOLVO VNL760 SLEEPER TRUCK (A59914)
2020 VOLVO VNL760...
2018 VOLVO VNL 670 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2018 VOLVO VNL 670...
2014 Ford Transit Connect Van (A61573)
2014 Ford Transit...
Landhonor 72" Skid Steer Power Rake (A62679)
Landhonor 72" Skid...
