I couldn't be happier
/ I couldn't be happier
So, with him on the way, he needs a place to sleep. My office is currently set up in the spare bedroom, so I'm gonna have to move. Another project starts. To the basement!
Got it stick framed, electrical, and good deal of drywall up. Next i need to grind the high spots in the floor then put down a moisture barrier and pergo flooring. It's a floating slab on top of hte existing slab that allows water to travel under it to the sump pump.
I ordered a radon detector to see what my radon levels are. That should arrive tomorrow. Depending on the levels I may have to install a radon pump. My heat is baseboard hot water, so radon was was really never a concern.
If it's stupid but works, it isn't stupid.
Got a concrete grinder and ground out all the high points on the floor. The dust almost killed me. Full face respirator thankfully did it's job. Cleaned that up and put out a vapor barrier and started the pergo flooring. What a pita that stuff is sometimes. Also managed to get a perfect cut around the existing wall. That was tricky. Once I get the tricky stuff ironed out, it should go much faster.
/ I couldn't be happier #24
Very good work fatjay! Thanks for the photo tour.
/ I couldn't be happier #26
Congrats, everything looks great!
Just found out I'm getting a granddaughter. Can't wait.
/ I couldn't be happier #29
Congrats Jay, but either you worked you a** off getting ready for the bundle of joy, or you ain’t all that fat ! 🤔
/ I couldn't be happier #33
It feels about the same if I’m honest. But it’s nice to be able to see the old chap without a mirror.
Quite apparently you have reacquainted you wife with the old chap last year!
2004 Winnebago Adventurer 38G 38ft. Class A Motorhome (A59231)
2004 Winnebago...
2007 MACK CHN613 6X4 T/A DAY CAB TRUCK TRACTOR (A59909)
2007 MACK CHN613...
CUSHMAN REFRESHER GAS GOLF CART (A63276)
CUSHMAN REFRESHER...
John Deere 4230 Tractor w/ Loader Bucket and Hay Spear (A64047)
John Deere 4230...
Yamaha Golf Cart (A64047)
Yamaha Golf Cart...
Mini rock grapples (A61567)
Mini rock grapples...
