Ford 1100 pressure plate
/ Ford 1100 pressure plate #1
retiredsnipe@62
Ford 1100
These seem to be made of unobtainium. Sent my core to rebuilder only to be told it wasn't serviceable. I spoke with about every tractor and clutch company in the US. I found a Nissan unit for a 6-1/4" disc that I bought on eBay. I have no idea if it will fit, but am out of options to use the original disc. Anyone else come across this issue? The tractor is sweet other than this! Thank you
/ Ford 1100 pressure plate #2
Welcome to TBN!
I don't see why an outfit can't reline it, but you might as well buy one of these aftermarket.
I was able to purchase a new disc, it is the plate that has a damaged diaphragm.
/ Ford 1100 pressure plate #4
This is what I need
/ Ford 1100 pressure plate #6
So sorry, reading on my phone and I was tired. (I know, excuses…..)
Anyway, have you researched this:
and
I‘m thinking you may have to change the flywheel to a 1200, 1210, 1220, TC21, but then you have an option. Just too many different sizes to manufacture.
Thanks, I have ordered the Nissan plate off eBay and am awaiting it's arrival. I will let you know if it's even close. I am hoping to avoid the removal and redrilling of the flywheel. I believe the larger clutch assembly would fit in the bell housing if I have to go there. That is plan "B" or "C"😩
/ Ford 1100 pressure plate #8
Actually, the bell housing is the same on 11, 12, 13, 15, 17, 1900 tractors
Wish they had standardized the clutch! Thanks for the info.
2024 JCB 35Z (A60462)
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
213086 (A64276)
213086 (A64276)
SCAN TO RECEIVE TEXT UPDATES (A65053)
SCAN TO RECEIVE...
2008 Dynapac CA150D (A60462)
2008 Dynapac...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
