What's your average mpg?
/ What's your average mpg? #22
2007 Saturn Vue 24mpg
2016 HONDA CRV AWD 31mpg
2014 Yamaha FZ09 50mpg
2019 Yamaha R3 70mpg
/ What's your average mpg? #25
Removed - do I win Last Place?
Now my average is just over 16 MPG
/ What's your average mpg? #26
Let’s see recent list
Toyota Tacoma 2x4 - 19.3 over 19,000 mi
Toyota Tacoma 2x4 - 20.3 over 6,000 mi
2001 Dodge 2500 4x4 6spd Diesel - 15.1 over 200,000 mi
2017 F150 4x4 V8 - 17.2 over 100,000 mi
2011 Ram 3500 SRW 4x4 - 14.2 over 230,000 mi
2015 BMW X5d - 27.6 over 165,000 mi
2020 F150 4x4 ecoboost - 17.3 over 61,000 mi
2022 Ram 3500 SRW 4x4 - 14.4 over 14,000 mi
2022 Lexus NX350h - 32.4 over 28,000mi
2022 Tesla M3LR - 21,143kWh over 67,000mi
Hmm where is my 2003 and 2011 Jetta data? The 2003 would help my average.
/ What's your average mpg? #27
F150 Powerboost 21mpg
Subaru forester 29.8
Toyota Avalon hybrid 39
/ What's your average mpg? #28
Had a '97 GMC G30 Van for a while. It was automatic, two wheel drive and, had a 454 with throttle body injection. It got 12 MPG. Didn't matter if I hyperdrove it, or if I towed 3,000 pounds. It got 12 MPG. Tried all manner of things to see if I could get 15...... Over inflate tires, pull in the side mirrors, turn off A/C, nope, it got 12 MPG. It was like this truck was set, to only do 12 MPG. Like, it was programed to do that.
/ What's your average mpg? #29
Same situation here!
In 1976 I bought a new GMC "Vandura" Terravan 4x4 conversion van. 400ci V8, 3.73 gears. Drove that thing for over 32 years - averaged 12 mpg.
After 32 years of rough roads it was either sink a lot of money into the GMC or get something newer. Found a 2007 Ford E350 4x4 conversion van for a really good price - 6.8 V10 with 3.73 gears. It got 12 mpg but shifted out of overdrive on every hill so I had both axles regeared to 4.56 ratio. Much better driveability...and after 70,000 miles overall fuel mileage is still 12 mpg!
So maybe all vans are programmed to get 12 mpg!
/ What's your average mpg? #31
2005 A4 1.8T 138KPH = 30 mpg 110 = 49 120 = 33-35
2014 TDI 53-56
2013 TDI deleted 57-60
2001 TDI 51- 55
1990 Cummins 2wd 22
1998 Cummins 4x4 22 Pulling holiday trailer 14
My son's F150 2.7l V6 Pulling same holiday trailer 14
These are all calculated mileage numbers in Imperial gallons. Us gal = imp gal divided by 5 x 4. We do very little town driving. kph divided by 1.609 = mph
/ What's your average mpg? #32
2016 Duramax 3/4 ton not hauling anything 20+mpg recently replaced trans fluid with ams signature noticed a slight increase in mpgs and trans temp stays around 10 degrees cooler, Honda pilot 25mpg, my beater a older kia 4 cylinder 5 speed 30+ finally a 2018 chevy 4500 cutaway class C 9-10 mpgs all combined mpgs rarely putting the hammer down.
/ What's your average mpg? #33
This is fun and I'm a hyper miler at heart anyway..
Focus RS 6 speed hatch = 40.1 mpg Mine)
Dude, you must be an extreeeeme hypermiler if we are to accept a 40mpg avg figure, on a gas hog focus RS. Your compatriots are averaging around half that! Nice work! (or check your calculations, lol).
/ What's your average mpg? #34
My fleet is smaller than it used to be. Currently getting:
2019 F150 3.5L - ~20 mpg combined
2018 Mazda CX-9 - ~25 mpg combined
/ What's your average mpg? #35
I keep it well tuned and the tires at maximum sidewall inflation pressure and my tires are LRR (low rolling resistance tires too.
Very consistent at 40+ mpg and that is with the ac running in the summer too. Keep in mind it's a 6 speed manual, not a slusher automatic so I can and regularly short shift it and I always anticipate my stops and kick it into neutral and coast to the stop. I'd say 99% of the Focus's sold (well was sold as they don't make them anymore) are dual clutch automatics and that is a trouble prone transmission from the get go.
Mine is a single dry clutch, with the German built turbocharged 2.0 engine. Took me quite a long time to get it too. I do get that mileage in the summer, in the winter it drops off to about 35 because summer blend gas is different from winter blend around here at least.
It has way too much power if you want to tromp it, like 320 horses at full boost. I have in the past but very infrequently. Being 73 and retired, I'm never in any hurry to get anywhere, anyway.
The only issue with the 2.0 turbocharged engine is, you have to keep up on maintenace and oil changes, they are extremely sensitive to dirty oil and dirty air filters and being a GDI engine, I have to clean the intake system regularly. Later GDI engine have a pilot injector in the intake to mitigate carbon buildup, mine don't. Mine runs dry so regular cleaning is important.
One thing stands out. Almost everybody has a 30mpg car. Most have a 40 mpg car.
It's clear we choose to save on or payless to travel. I'm nearly 70 and I plan to run the VW TDI until it or I die.
Looks like we only need the opportunity to own efficient cars and we will.
/ What's your average mpg? #37
When you hit the 70 'milestone' everything is downhill from then on out.... :rolleyes:
/ What's your average mpg? #39
I think people get crazy about some this; the cost savings from 40mpg to 45 mgh is insignificant for most; while the difference between 15mpg and 20 mpg is huge. Also, it seems like some of the people most obsessed with these numbers, drive the vehicle way too little for the math to matter.
My work vehicle, I drive approx 4000 miles per month. Looks like right now, I'm sitting at 26.7 mpg over last 60 days or so; at $3.89/gal; that's $582/month. If that same vehicle got 35 mpg, that's still $444/month, or $138 less per month. That's a noticeable cost difference but not huge; and that's a pretty high milage per month, probably more than 75% of passenger vehicles. In order to move a 27 mpg vehicle to 35 mpg, while still keeping the same capacity, what is the cost?
If I drove a 1500 Ram 4x4 as a work vehicle (last truck, before we switched to exploders), 19 mpg=$818; moving to say 24 mpg=$648 or $170/month savings, with just a 5 mpg increase. I dont 'think' we really have the technology to make 30+% increases without major sacrifices in capacity.
/ What's your average mpg? #40
When we drive our Suburban to Oklahoma, about 875 miles, we're lucky to get 17-18mpg. When we take the Subaru, we get 34mpg. That's 100% better mileage, or, half the fuel costs. Round trip it's a bit over 100 gallons of gas VS about 50. @ $3.89/gallon = $389 VS $194.
Daily driving, I only do 10 miles per day. I get about 12 in the Suburban and about 22 in the Subaru. So 50 per week in the Suburban VS 50 per week in the Subaru is $16 VS $8.8.
I work about 48 weeks per year, so $768 for gas in Suburban VS $422 in Subaru for the year if I drove that instead as my commuter vehicle. That's only a $346 savings for yearly commute, or, about a dollar a day if you average it over the year.
So, if you drive a lot, high MPG vehicles are well worth it. Not so much if you don't put in the miles.
2025 Swict 84in Bucket Skid Steer Attachment (A64553)
2025 Swict 84in...
2019 Mercedes-Benz GLS 4 Matic AWD SUV (A64557)
2019 Mercedes-Benz...
2020 Inifiniti Q 50 Sedan (A64557)
2020 Inifiniti Q...
2001 Pierce Tilt Crew Cab Pumper Fire Truck (A61573)
2001 Pierce Tilt...
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
