TODAYS SEAT TIME
/ TODAYS SEAT TIME #13,281
You guys got hammered last month, didn't you!
The culvert in front of my Mom's home washed out twice. It started as an old steel 18" which was quickly overwhelmed, replaced with a 24" which washed out the next day, finally stuck a 36" in which has withstood the latest torrent but the state inspector has not issued a ruling on it an will likely insist on a 48". That size would have been used at the time the 36" went in but there were none available at the time due to everyone else in our area needing them. Still raining steady today but things appear to be holding🤞
/ TODAYS SEAT TIME #13,282
Had to knock down the brush in front of our raised blind. Downside of logging, it gets thick.
Used the mini. Not what the blade was designed for but it's all I had.
Also worked on the aspen that is starting to get crazy next to blind
Eventually I want to make a food plot in this area, kinda extend our existing food plot. Not this year though.
Our existing food plot that was planted yesterday.
Just takes time.
Was gonna take pics from inside the blind but sprayed some wasp nest, they were a little to pissed for me to go in there right now
/ TODAYS SEAT TIME #13,283
I do gotta put a hydraulic oil cooler on this thing. My right side drive motor is weak and need to start looking for another one but the fluid gets way to hot which doesn't help.
/ TODAYS SEAT TIME #13,284
I made a boo boo today while using the 7' brush hog:
Right front tire dropped into the end of the culvert:
Fortunately this G Series Toolcat has Traction Control and it backed right out:
/ TODAYS SEAT TIME #13,287
Today was another mowing day, and there's still more mowing to do,
SR
Is that the first mowing? Probably not, the grass is too green and there is too little mowed grass on top of it.
That's a nice looking field.
/ TODAYS SEAT TIME #13,288
I called it "mowing" and I should have called it rotary cutting. It was very thick in most places, but that field sat all day in the sun before I took the pict., so it dried down and doesn't look like much.
It was the first time cut this year.
All the guy wants is to have "nice looking fields", and that's what I'm trying to give him.
SR
More info coming soon! (A56859)
More info coming...
Hay King 12' Pasture Renovator (A60462)
Hay King 12'...
2007 STERLING L7500 TANDEM AXLE DUMP TRUCK (A59906)
2007 STERLING...
2024 Linx UT357710TG (A60463)
2024 Linx...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2017 FORD F-150XL CREW CAB TRUCK (A59823)
2017 FORD F-150XL...
